Rear End Control Arm Bushing Replacement - CSM Says No ?
Old October 9th, 2011, 03:28 PM
costpenn's Avatar
Replacing all the rear end control arm bushings on my 72 442 convertible. Have already dissasembled, and pushed out all the old bushings, bead blasted the arms etc. Was looking in the CSM as to proper way of installing the new bushings, but it says that the ones in the rear end housing can be replaced, but the bushings in the arms cannot be and replacement arms should be used - anyone know why?
costpenn is offline
Old October 9th, 2011, 03:41 PM
Oldsmaniac's Avatar
I am guessing that back in the day it was cheaper to just put new arms on than the labor and parts to replace. When you install the new ones in the arms support is needed else you will bend the arm...You need to put some sort of spacer in there so the U channel does not close up.
Oldsmaniac is offline
Old October 9th, 2011, 03:43 PM
Lady72nRob71's Avatar
They can be replaced, but the CSM was most likely suggesting it is more cost and time efficient to replace the entire arm assy.
Lady72nRob71 is offline
cdrod
February 26th, 2015 06:50 AM
costpenn
Suspension & Handling
18
April 20th, 2012 03:04 PM
oregontopcat
March 24th, 2011 07:17 AM
t bell
October 23rd, 2009 08:26 AM
tim72
Drivetrain/Differentials
April 3rd, 2009 09:00 AM
Quick Reply: Rear End Control Arm Bushing Replacement - CSM Says No ?
