Question
Old Oct 31, 2017 | 10:30 AM
Dave Belk's Avatar
Question
1971 oldsmobile cutlass supreme 350 engine questions:
Original AC Delco part # for air cleaner filter
Same for PCV valve
Same for coil
I am finding conflicting information on the internet.
Any help appreciated. Thanks. Dave
Old Oct 31, 2017 | 10:41 AM
All these parts are available over the counter at your parts store if your not doing a nut and bolt resto.
Old Oct 31, 2017 | 10:45 AM
Dave Belk's Avatar
It is for a car i am having certified at MCACN. Thanks. Dave
Old Oct 31, 2017 | 01:53 PM
RetroRanger's Avatar
72 Olds CS
what does that mean? certified as in ?
Old Oct 31, 2017 | 04:18 PM
Same for PCV valve
Same for coil
Dave,
Got your voicemail, but I figured it would be easier to respond in writing. These part numbers all come from the Jan 1972 printing of the Parts Book.
You didn't specify with or without O.A.I. I assume it's a 4bbl.
With O.A.I., the air filter is P/N 6485166, which is AC P/N A366 C
Without O.A.I., the air filter is P/N 6421746, which is AC P/N A212 CW
PCV valve is P/N 6421972, which is AC P/N CV 679C
Coil is P/N 1115238
Old Nov 1, 2017 | 07:26 AM
Dave Belk's Avatar
Thanks Joe! Appreciate it!
Old Nov 1, 2017 | 09:51 AM
Dave Belk's Avatar
Joe, question on the coil. There are "white lettered" printed versions on the coil, or "raised embossed" 238 B-R. Which is correct? Appears to be same coil / part numbers, but "written or raised embossed " on the coil. Thanks! Dave
442fanatic
Jun 12, 2017 04:42 AM
lemoldsnut
Sep 30, 2015 10:05 AM
yeahbuddy
Dec 19, 2011 08:40 PM
