Question
Question
1971 oldsmobile cutlass supreme 350 engine questions:
Original AC Delco part # for air cleaner filter
Same for PCV valve
Same for coil
I am finding conflicting information on the internet.
Any help appreciated. Thanks. Dave
Same for PCV valve
Same for coil
Got your voicemail, but I figured it would be easier to respond in writing. These part numbers all come from the Jan 1972 printing of the Parts Book.
You didn't specify with or without O.A.I. I assume it's a 4bbl.
With O.A.I., the air filter is P/N 6485166, which is AC P/N A366 C
Without O.A.I., the air filter is P/N 6421746, which is AC P/N A212 CW
PCV valve is P/N 6421972, which is AC P/N CV 679C
Coil is P/N 1115238
Joe, question on the coil. There are "white lettered" printed versions on the coil, or "raised embossed" 238 B-R. Which is correct? Appears to be same coil / part numbers, but "written or raised embossed " on the coil. Thanks! Dave
lemoldsnut
Sep 30, 2015 10:05 AM
