What are the widest and tallest tires you can fit in the rear of a 67 Cutlass?
Old Feb 17, 2020 | 02:46 PM
Coastie's Avatar
Stock cars are too boring
I've got air shocks, so I can get a little more clearance. Im looking at a set of 315/50r15 tires to slap on the rear.
Old Feb 17, 2020 | 02:58 PM
Oldsmaniac's Avatar
You need to get the proper wheels/backspace for the width of the tires used. I would suggest an 8 inch wide wheel with a 5 inch backspace. Not sure if those 50's width tires will fit/clear.
Old Feb 17, 2020 | 03:15 PM
I'm thinking you mean 325 50 15. Your going to need a 10" wide wheel with around a 5" back spacing. You do not want to depend on air shocks with a tire that may interfere with the body or chassis at lower heights. Your also getting into a drag radial or a dot tire that's really not recommended for the street.
Old Feb 17, 2020 | 05:13 PM
Coastie's Avatar
I've got some 2" wheel spacers for the back. The set up was currently fitted to an 80s monte Carlo. As far as use on the road; safety has been thrown to the wind
Old Feb 17, 2020 | 05:46 PM
While I agree that some modern things are not applicable, safety items should be at least what was original equipment and NOT downgraded from EOM standards.
Old Feb 18, 2020 | 01:15 AM
69CSHC's Avatar
N50 15
Test fit the tire about 20 years ago on the 67 Cutlass Holiday Coupe that I had at the time. Stock rear end, with 15 x 8 Centerline. Unfortunately I do not remember backspacing etc, and no pics to the best of my recollection.
It did fit with no contact, the car had all new suspension. Definitely the largest tire I ever had on the car. The look was too big for my taste at the time. Although the tires alone looked great !
Old Feb 18, 2020 | 04:21 AM
If your careful with the measurements, you can get a 325/50R15 drag radial on the rear. I have a friend with a 66, he ran that size for years. I really wish someone would make that size tire in regular radial tire construction. That tire looked badass on the back of my 69, and his 66. The drag radials don’t last long, and after driving for a while the tires get warm and pick up every rock and throw it against the quarter panel.
mzbk2l
Wheels and Tires
Jun 9, 2018 08:35 AM
bulldogs#10
Wheels and Tires
Jul 3, 2015 08:52 AM
Her69olds
Wheels and Tires
Nov 6, 2014 08:24 PM
mcutlass1969
Jun 8, 2009 09:37 AM
ragtop442
Jul 4, 2008 12:13 AM
