Steering Wheel
If your real question is, can you put a four spoke sport wheel on a smaller diameter early column, the answer is yes, however as noted the hub will be larger in diameter than the column and looks a little silly. The solution is to use the hub from a 1965-66 Impala two-spoke wheel that is the right diameter and has the same six screw pattern for the wheel. These are available from Chevy repro houses.
sjay1989
September 25th, 2019 04:12 PM
