Steering Wheel
Old Sep 9, 2019 | 06:47 PM
Hammerdrop's Avatar
Steering Wheel
Will a steering wheel from a 71 Cutlass fit a 68 Cutlass. That is before the ignition lock was on the column to when it was and is.
Thanks All
Old Sep 9, 2019 | 07:00 PM
svnt442's Avatar
The splines are the same, but the column isn't as large so the wheel base sticks out passed the top of the column.
Old Sep 10, 2019 | 05:53 AM
If your real question is, can you put a four spoke sport wheel on a smaller diameter early column, the answer is yes, however as noted the hub will be larger in diameter than the column and looks a little silly. The solution is to use the hub from a 1965-66 Impala two-spoke wheel that is the right diameter and has the same six screw pattern for the wheel. These are available from Chevy repro houses.
Old Sep 10, 2019 | 04:18 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Dam Joeseph...we have to start a thread of what Joe-dont-know! Should have 3 or 4 maybe 5 posts?
Old Sep 10, 2019 | 06:41 PM
Hammerdrop's Avatar
Thanks All............Hammer
sjay1989
Sep 25, 2019 04:12 PM
67442nut
Jun 27, 2015 10:40 PM
Eaglesfan
Aug 9, 2014 05:57 AM
cheven
Apr 5, 2012 10:05 AM
colby
Oct 1, 2009 02:55 PM
