Rag joint
Rag joint
Is there a trick to get the rag joint open enough to get it on the steering shaft?
I have a Lares 200 which states it's 3/4 which matches the shaft diameter but the rag joint inside diameter it's closer to .67
I tried prying the ears open and maybe got an extra hundred or two.
Tim you could try calling lares directly they might be able to help .They were very good helping me figure out the upgrades to the steering box and coupler on my gbody.they may ask you to physically count the splines on your out put shaft ( not an easy task with my aging eyes)
http://catalog.larescorp.com/part/201/
interesting,
Not sure if this is the one I got but.
https://www.camarocentral.com/1967_1...e_p/pow-62.htm
New Complete Power Steering Rag Joint Coupler for 67 - 76 Camaro models. This rag joint coupler mounts the lower steering column to the power steering gear box. Premium quality P/S Rag Joint Coupler at a budget friendly price, order yours today! Steering Coupler With Power Steering For 13/16" Shaft - 36 Full Spline or 31 Spline with Flat Spot. This measures 3-1/4" Diameter. This coupler rag joint is required to connect the steering column to the steering box.
Fits 13/16" Input Shafts
Also fits: 64-72 GTO / LeMans, 64-72 Chevelle, 64-72 Olds Cutlass, 67-76 Firebird.
Replaces GM PART# 7828871 and 7806390
