Rag joint
Old Apr 18, 2022 | 09:20 PM
tkcutlass's Avatar
Rag joint
Is there a trick to get the rag joint open enough to get it on the steering shaft?
I have a Lares 200 which states it's 3/4 which matches the shaft diameter but the rag joint inside diameter it's closer to .67
I tried prying the ears open and maybe got an extra hundred or two.
Old Apr 19, 2022 | 04:13 AM
Correct coupler?
Lares 200 = 3/4" 25 Spline Input Shaft
Lares 201 = 13/16" 31 Spline Input Shaft
Old Apr 19, 2022 | 06:03 PM
tkcutlass's Avatar
Few pics of what I am looking at.
Old Apr 20, 2022 | 04:42 AM
deadeyejedi's Avatar
Tim you could try calling lares directly they might be able to help .They were very good helping me figure out the upgrades to the steering box and coupler on my gbody.they may ask you to physically count the splines on your out put shaft ( not an easy task with my aging eyes)
Old Apr 20, 2022 | 11:53 AM
70Post's Avatar
It looks like you probably received a rag joint for a manual steering box. The measurements inside that you show on the new rag joint match up to some manual box rag joints I have here.
Old Apr 20, 2022 | 01:32 PM
tkcutlass's Avatar
Just got off the line with summit, they are going to measure to verify they don't have a bad batch and get back to me.
I can't imagine the .68 can be stretched to .75
Old Apr 20, 2022 | 04:42 PM
fleming442's Avatar
Count the splines, so you know for sure
Old Apr 28, 2022 | 05:54 PM
tkcutlass's Avatar
Once again I was wrong.
Talked to Hector who rebuilds the fast ratio boxes (which I got from him) and he sent me the correct coupler which is 13/16 36 spline.
Old Apr 28, 2022 | 06:02 PM
I don't believe you ever stated what vehicle this was for....likewise I'm not certain if you stated the gear box. You're sure about the 36 spline? I thought the Lares 201 was a 31 spline? Post #2
http://catalog.larescorp.com/part/201/
Old Apr 28, 2022 | 06:08 PM
I thought the 36 spline was 3/4" and the 31 spline was 13/16"?
Old Apr 28, 2022 | 06:18 PM
Old Apr 28, 2022 | 08:34 PM
tkcutlass's Avatar
interesting,
Not sure if this is the one I got but.
https://www.camarocentral.com/1967_1...e_p/pow-62.htm
New Complete Power Steering Rag Joint Coupler for 67 - 76 Camaro models. This rag joint coupler mounts the lower steering column to the power steering gear box. Premium quality P/S Rag Joint Coupler at a budget friendly price, order yours today! Steering Coupler With Power Steering For 13/16" Shaft - 36 Full Spline or 31 Spline with Flat Spot. This measures 3-1/4" Diameter. This coupler rag joint is required to connect the steering column to the steering box.
Fits 13/16" Input Shafts
Also fits: 64-72 GTO / LeMans, 64-72 Chevelle, 64-72 Olds Cutlass, 67-76 Firebird.
Replaces GM PART# 7828871 and 7806390
Macadoo
Suspension & Handling
21
Jul 4, 2019 06:44 PM
My2nd 69 442
Apr 17, 2018 04:09 PM
MudEye
Mar 2, 2018 09:02 PM
kstern58
Nov 4, 2014 04:48 AM
#1CutlassSupreme
Jun 5, 2009 09:22 AM
