Radiator hose question
Old Sep 8, 2022 | 06:36 PM
AK71CutlassS's Avatar
I’ve beat the search function to death
i have a 1971 Oldsmobile Cutlass S
455.
water pump outlet 2 inch
radiator 3 core with 1.75
i got the gates 20603. It has the wrong size ends but the right shape hose
then got the gates 20601 it has the RIGHT ends but wrong shape.
looking for info on the correct lower hose.
Any help much appreciated
Old Sep 8, 2022 | 06:48 PM
therobski's Avatar
There are hose sleeves to help with this issue. Napa and others have sleeve adapters...Ask me how I know....
Old Sep 8, 2022 | 06:53 PM
Someone has to sell the correct hose
QUOTE=therobski;1451934]There are hose sleeves to help with this issue. Napa and others have sleeve adapters...Ask me how I know....[/QUOTE]
Old Sep 8, 2022 | 07:13 PM
455.
It appears you have a 1970 cooling system setup on your '71 - I have similar on my car.
The 1971-newer engines have a 1.5" radiator outlet and 1.75" water pump inlet.
The 1970-older engines have a 1.75" radiator outlet and 2" water pump inlet.
So I would have thought the 20601 hose would work. I've never had any problems with lower hose fitment on my car.
Old Sep 8, 2022 | 07:16 PM
therobski's Avatar
[/QUOTE]
Whatever just trying to help....
Old Sep 8, 2022 | 07:21 PM
Old Sep 8, 2022 | 07:23 PM
Here’s what I got 603 on left. The one I need in middle. 601 on right
Old Sep 8, 2022 | 07:44 PM
bccan's Avatar
*** Fusicks ***
Yup, you’ll pay a little more but I’ve found the repro hoses fit a lot better than parts store versions.
Old Sep 8, 2022 | 07:49 PM
Maybe you can trim the 601 to fit? That may be what I did in the past. It looks as if the lower end is trimmed a bit that it would match the middle one.
Old Sep 9, 2022 | 06:10 AM
^^^THIS! The water pump is not correct, thus the hose problem. Also note that a lot of replacement radiator vendors sell the small outlet radiators for all applications to cut the size of their inventory and cost, forcing you to use the bushing for some applications.
Old Sep 9, 2022 | 07:58 AM
therobski's Avatar
X2 on that Joe.I have used the rubber sleeves from Napa on a few builds, notta issue..
Dave S
Jun 11, 2021 07:56 PM
Tom442
Jun 12, 2017 05:51 PM
cutlassquad
Apr 12, 2013 08:57 AM
matviar
Apr 9, 2012 12:56 PM
OldsManNJ
Mar 23, 2011 08:47 AM
