Lower Radiator hose question 67' cutlass
Old Jun 11, 2021 | 07:01 PM
Dave S's Avatar
I'm Seeking advice on my lower radiator hose, 1967 cutlass, 330 v8.
The radiator has a 1.5" lower port. The new hose I purchased is 2" at the water pump but 1.75" at the radiator.
Is the correct hose available? am I missing something? When looking at new radiators they call the lower port to be 1.5" (Same as mine)
I ordered a 1.75 to 1.5" adapter sleeve but would prefer the correct hose.
Any help is appreciated.
Thanks.
Dave
Old Jun 11, 2021 | 07:31 PM
The early engines (1970-older) used a water pump and radiator with a larger lower radiator hose fitting. Almost all the aftermarket radiators and water pumps (such as Flow Kooler) use the 1971-later smaller lower hose fittings.
So it appears that someone replaced the radiator with a 1971-up version, and you will need to figure out a hose adapter solution.
Old Jun 11, 2021 | 07:56 PM
The hose adapter works fine.
vickycar
Mar 28, 2017 02:13 PM
squirell
Aug 25, 2009 09:21 AM
jdanieljones
Dec 28, 2008 01:55 PM
Iragh
Nov 17, 2008 01:23 PM
harleyrules
Nov 25, 2007 07:22 PM
