Quick Redline Question
Old Jun 6, 2016 | 10:28 PM
JRev's Avatar
This might be a dumb question, but I'm wiring an after market tachometer and was wondering what is the redline or way to figure out my redline. Its a 1972 Cutlass Supreme, 350, 4 Barrel, 3 speed automatic on the column.
Old Jun 7, 2016 | 03:16 AM
Are you shifting the transmission manually or installing a shift kit?
If not, it doesn't matter. The transmission will shift when it was designed to, and if you observe where that point is, it is your redline. It will probably be around 4,500 RPM.
If you want to set the little marker at 5,000, go ahead - you should be able to get away with revving a stock engine to 5,000, though you aren't likely to get any more power out of it that way.
Old Jun 7, 2016 | 05:09 AM
If your just wondering where to put the pointer on the tach, I second the 5k redline for a relatively stock 350.
oldrag71
Dec 28, 2010 05:30 PM
64starfire
May 6, 2009 10:24 PM
Redog
Jul 11, 2008 10:38 PM
smcurro
Jul 8, 2007 10:23 PM
Old64Olds
Oct 24, 2002 05:29 AM
