protecting bare metal frame?
Old September 20th, 2013, 09:41 AM
chadman's Avatar
I just had the frame blasted for my '69 race car project. I will need to do some welding and fabricating for numerous race related items on it in the upcomming months. I am looking for suggestions to keep it from flash rusting during the time period it takes to accomplish this. So far the two options I have considered are to 1) shoot it with epoxy primer and just grind it away where I need to cut and weld or 2) spray the entire frame down with WD-40 periodically.
The only thing that scares me about the WD-40 route is possible adhesion issues when it comes time for paint. I figured I could just hose it down with brake cleaner to wash away the WD-40 prior to paint. Thoughts?
chadman is offline
Old September 20th, 2013, 09:47 AM
Flash rust can easily be removed with numerous products on the market if you just want to leave it bare for awhile during the work. Assuming you're working on this inside. If painting, epoxy primer sounds good. I wouldn't want to spray the frame down with anything that could affect paint adhesion either.
Allan R is offline
Old September 20th, 2013, 11:19 AM
Olds442redberet's Avatar
Try Phosphos. I think that's how it is spelled. It is available at ACE hardware and it will protect the frame while your aorking on it.
Olds442redberet is offline
Old September 20th, 2013, 11:35 AM
I vote for option 1. Shoot primer now, grind off where you are welding, sand and reprime when the welding is complete.
joe_padavano is offline
Old September 20th, 2013, 11:56 AM
ABSOLUTELY DO NOT DO THIS (before welding on the frame)!
I recently read in a motorcycle magazine that this is a bad practice. Apparently, brake cleaner contains chemicals that will convert to TOXIC gas when heated (I think phosgene).
The author of the article did some welding on his motorcycle frame after cleaning it with brake cleaner. A small pocket of brake cleaner was left on the frame and flashed into toxic gas. He inhaled it and was in the emergency room for days. He mentioned he is lucky to be alive.
I tried to find the article, but I think one of the guys in the office carried the magazine back to the barracks.
Olds64 is offline
Old September 20th, 2013, 12:02 PM
chadman's Avatar
That it only the case with chlorinated brake cleaner. I use non-chlorinated.
chadman is offline
Old September 20th, 2013, 12:05 PM
I recall that was mentioned in the article.
Olds64 is offline
Old September 20th, 2013, 12:13 PM
car guy
gearheads78's Avatar
Best stuff out there but its expensive.
I know this is some one elses product repackaged but I can't remember what it is.
http://radrides.com/index.php?option...ant&Itemid=579
gearheads78 is offline
oldsmansugar
Paint
October 24th, 2013 12:19 PM
lvelocci
Body work
24
August 9th, 2011 08:21 PM
72 Olds Project
May 6th, 2011 04:01 AM
BklynBob
15
August 29th, 2008 09:46 AM
Keieljun
April 28th, 2008 03:25 AM
Quick Reply: protecting bare metal frame?
