protecting bare metal frame?
Old Sep 20, 2013 | 09:41 AM
chadman's Avatar
I just had the frame blasted for my '69 race car project. I will need to do some welding and fabricating for numerous race related items on it in the upcomming months. I am looking for suggestions to keep it from flash rusting during the time period it takes to accomplish this. So far the two options I have considered are to 1) shoot it with epoxy primer and just grind it away where I need to cut and weld or 2) spray the entire frame down with WD-40 periodically.
The only thing that scares me about the WD-40 route is possible adhesion issues when it comes time for paint. I figured I could just hose it down with brake cleaner to wash away the WD-40 prior to paint. Thoughts?
Old Sep 20, 2013 | 09:47 AM
Flash rust can easily be removed with numerous products on the market if you just want to leave it bare for awhile during the work. Assuming you're working on this inside. If painting, epoxy primer sounds good. I wouldn't want to spray the frame down with anything that could affect paint adhesion either.
Old Sep 20, 2013 | 11:19 AM
Olds442redberet's Avatar
Try Phosphos. I think that's how it is spelled. It is available at ACE hardware and it will protect the frame while your aorking on it.
Old Sep 20, 2013 | 11:35 AM
I vote for option 1. Shoot primer now, grind off where you are welding, sand and reprime when the welding is complete.
Old Sep 20, 2013 | 11:56 AM
ABSOLUTELY DO NOT DO THIS (before welding on the frame)!
I recently read in a motorcycle magazine that this is a bad practice. Apparently, brake cleaner contains chemicals that will convert to TOXIC gas when heated (I think phosgene).
The author of the article did some welding on his motorcycle frame after cleaning it with brake cleaner. A small pocket of brake cleaner was left on the frame and flashed into toxic gas. He inhaled it and was in the emergency room for days. He mentioned he is lucky to be alive.
I tried to find the article, but I think one of the guys in the office carried the magazine back to the barracks.
Old Sep 20, 2013 | 12:02 PM
chadman's Avatar
That it only the case with chlorinated brake cleaner. I use non-chlorinated.
Old Sep 20, 2013 | 12:05 PM
I recall that was mentioned in the article.
Old Sep 20, 2013 | 12:13 PM
gearheads78's Avatar
car guy
Best stuff out there but its expensive.
I know this is some one elses product repackaged but I can't remember what it is.
http://radrides.com/index.php?option...ant&Itemid=579
oldsmansugar
Paint
Oct 24, 2013 12:19 PM
lvelocci
Body work
24
Aug 9, 2011 08:21 PM
72 Olds Project
May 6, 2011 04:01 AM
BklynBob
15
Aug 29, 2008 09:46 AM
Keieljun
Apr 28, 2008 03:25 AM
