Please help me!!!!!!!!
Old Dec 31, 2017 | 03:04 PM
  #121
76olds's Avatar
Hookers under Hood
Before I go one last thing here, if you have spark, you may be 1 position out if the rotor didn't line up just correct with the number 1 plug, move the distributor like Oldscutlass mentioned until it fires up. If its running really ruff just move the plugs wires clockwise one position, then get the timing in." Only if its out 1 placement"
Cheers
Eric
Old Dec 31, 2017 | 03:08 PM
  #122
tim30's Avatar
I think you are getting close. I am expecting that response saying she is running. By the way, buy a factory service manual and not a Chilton manual. Some people should not be making recommendations. Ebay will have plenty of factory service manuals. The prices will vary considerably.
ok will do
Old Dec 31, 2017 | 03:09 PM
  #123
tim30's Avatar
Originally Posted by 76olds
Your really close now Tim.
Your in good hands with Oldcutlass he will get your car running, I have to go out for the night now.
Happy New Year to all!
Cheers
Eric
Thanks Happy New Year
Old Dec 31, 2017 | 03:10 PM
  #124
tim30's Avatar
You may need to rotate the distributor cw a bit. DO you have spark?
Im not getting spark
Old Dec 31, 2017 | 03:57 PM
  #125
cherokeepeople's Avatar
try a new set of points,i bet you burned em out messing with the wires.
Old Dec 31, 2017 | 04:28 PM
  #126
tim30's Avatar
OK ill go grap some tomorrow
Old Dec 31, 2017 | 04:35 PM
  #127
tru-blue 442's Avatar
Old School Olds
Don't forget a condenser.
Old Dec 31, 2017 | 04:38 PM
  #128
tim30's Avatar
So get the condenser and points... Do I need anything else for setting it??
Old Dec 31, 2017 | 04:46 PM
  #129
Old School Olds
The points need to be set at the high step of the dist. cam. I always use a dwell meter
at 28-30*. A feeler gauge will work too.
Old Dec 31, 2017 | 04:48 PM
  #130
tim30's Avatar
Ok thanks. How do I know the one I have isnt working or burned. Should I remove it now to inspect>?
Old Dec 31, 2017 | 04:53 PM
  #131
Old School Olds
Good question. I have had condensers go bad and the points won't spark.
That may be all that is the matter as well. If you change points, change the condenser.
Old Dec 31, 2017 | 06:02 PM
  #132
tim30's Avatar
Ok thanks
Old Dec 31, 2017 | 07:08 PM
  #133
the old delco number is d1007.this is the points/condenser all in one.remove the rotor and loosen the 2 screws holding the points a couple turns BUT do not take them out,reason:you drop em below the point plate they are hell to fish out.also there will be a little capsule with the points this is the grease for the rubbing block,put a little and i mean a little on the edge of the rubbing block the rest behind it so it can rub off on the cam of the distributor.alot of times if they are preset you can put the points in and press them against the screws and tighten and be real close on dwell to the point it will start and run.
Old Dec 31, 2017 | 07:17 PM
  #134
tim30's Avatar
Ok I will be doing this tomorrow but your warnings got me on my toes so ill be careful
Old Dec 31, 2017 | 07:18 PM
  #135
there is the old saying"you learn from your mistakes"this may be frustrating as hell but the knowledge you gain from it will be priceless.electrical gremlins can make you pull hair,believe me.just restored an 85 el camino this spring got it together and could not for the life of me get the left front turn signal to work.fought that thing off and on for 2 weeks.finally thought to change the socket and sure as heck that was it,but testing with a test light and meter said it was good.
Old Dec 31, 2017 | 07:25 PM
  #136
fleming442's Avatar
#1 doesn't have to be pointed at the #1 cylinder; it just has to line up with a terminal on the cap and THAT terminal is where you start the firing order COUNTER CLOCKWISE ON AN OLDS.
Have you verified power to the coil?
Power to the points?
Also, 0* is TDC, but it'll run better once fired, if you start at 16.
Old Dec 31, 2017 | 07:29 PM
  #137
Old School Olds
Pick up one of these when you get a chance. One of the best tools you can have.
https://www.googleadservices.com/pag...9aACCEM&adurl=
Old Dec 31, 2017 | 07:37 PM
  #138
tim30's Avatar
I lined it up to Terminal one on the Dis Cap.
Im getting power to the coil as I tested the power and the ground that running from the Dis.
Power to Points?
  #139
tim30's Avatar
Very True will order tomorrow Its cheap too thats a great deal
Old Dec 31, 2017 | 07:39 PM
  #140
tim30's Avatar
This is very true and truely a honor to get to learn it and I know itll all pay off once I get her running again. Im taking everything everybody saying and trying my best to do it correctly and in order. Happy New Year to everybody as its soon coming
Old Dec 31, 2017 | 07:45 PM
  #141
sooner for you!i'm in central time zone happy new year to you to and thanks for your service.
Old Dec 31, 2017 | 07:47 PM
  #142
tim30's Avatar
I am also!Its 9:47 here
Old Dec 31, 2017 | 08:06 PM
  #143
truckman5000's Avatar
W30
what if you swap to an electronic deal, like pertonix.
i have the crane version and never had an issue with setting up anything, dont want to sound stupid but i am with points kits.
Old Dec 31, 2017 | 08:50 PM
  #144
oh k thought all florida was eastern.
Old Dec 31, 2017 | 09:07 PM
  #145
tim30's Avatar
Nope not the Pan Handle..... which shocked me also when I moved here
Old Dec 31, 2017 | 09:09 PM
  #146
redoldsman's Avatar
Proud Viet Nam Veteran
The car was running before he pulled the distributor the change the intake manifold gaskets. I am not sure he should start throwing parts at it. Granted he may have burned the points but if was not getting any power to them that would not be the case. At the end of the day however, it might make sense to replace the points and the coil. At least you know they are good. If that does not fix it, it is time to call somebody to help. I don't think there is anything else we can recommend.
Old Dec 31, 2017 | 09:20 PM
  #147
tim30's Avatar
Very true thanks for the recommendation because I didnt wanna just start buying things...I didnt even know the points could get burned and not work. I never work with them before so I know this will be a task also
Old Jan 1, 2018 | 07:58 AM
  #148
he was trying everything.so if he put the hot wire to the coil on the - side with the wire to the points and tried to start even with just key on he would have full 12 volts to points,they don't live long with 12 volts.
Old Jan 1, 2018 | 08:10 AM
  #149
Tedd Thompson's Avatar
I'm late to this game and I'm not going to start recommending anything in the way of parts(you have many experts who know there way around a distributor here already) but when you finally get that engine running if mine I would start replacing all the wires from around or near that distributor.Someone has hacked that wiring in the past badly and It has caused a lot confusion and probably- maybe some of your issues with starting. It sorta looks like there might have been a major short there at sometime... Just a thought ...Tedd
And as a after thought... I've always been able to see if points were burnt just by looking at the contact pads or placing a screwdriver across them and see if they sparked. If not work backwards till you get juice.... Best of luck and a Happy New Year.
Old Jan 1, 2018 | 09:54 AM
  #150
tim30's Avatar
Thanks for the comment. The wires are how they came from the factory. They were taped by me. They are all the way they should be I tapped them to give it a fresher look because the old tape was dry and brittle. I just tapped them with the job I did to them this past week all are tapped the way they were together from the factory I didn't going any together or crossed any
Old Jan 1, 2018 | 10:02 AM
  #151
tim30's Avatar
Wait I just tried this with the key in (on) position and the black cord on the meter running to the (-) side of the coil and the red to the (+) side of the coil and Im not getting 12 volts with all wires hooked up on coil
Old Jan 1, 2018 | 10:18 AM
  #152
Because the points are probably open. If your doing any kind of voltage measurement the black lead from the meter needs to be connected to the engine block.
Old Jan 1, 2018 | 10:19 AM
  #153
tim30's Avatar
Oh Well Im on the way to get new ones
Old Jan 1, 2018 | 10:22 AM
  #154
Did you check the wiring between the coil and your points and the ground inside the distributor?
Old Jan 1, 2018 | 10:30 AM
  #155
tim30's Avatar
No how do I check
Old Jan 1, 2018 | 11:41 AM
  #156
back in post 83 i said how to test these.but again.pull cap remove wire from - side of coil.with meter set to ohms touch one lead to the wire from the coil the other lead to the screw holding the wire onto the points,meter should read 0
Old Jan 1, 2018 | 12:56 PM
  #157
tim30's Avatar
Yes it's reading 0
Old Jan 1, 2018 | 01:42 PM
  #158
o.k. its good.did you get some points
Old Jan 1, 2018 | 01:58 PM
  #159
tim30's Avatar
Yes but I would be a lie I said I wasn't intimidated
Old Jan 1, 2018 | 02:41 PM
  #160
easy to do only hard if you make it hard.as i said unscrew the 2 holddown screws but DO NOT remove them.they will need to be out 2 or 3 turns,the notch on the bottom of the points "in that pic"will set over the screw first then rotate it around and get the other one in its notch it will slide under the second screw but takes a little finesse.once there press the points towards the main shaft it just needs to bottom against the back screw so you don't need to press that hard,then tighten.put the wire back on the points, rotor and cap on make sure all coil wires are where they need to be and see if it starts.if not pull a wire and check for spark.
