Original alternator?
Old Mar 6, 2025 | 05:00 PM
72455's Avatar
1972 U code Supreme
I need to replace the alternator on my '72 Supreme and was able to source a 63 amp version. The one on the car now is a Delco Remy but how would I know if it's original? I ask because if it is, I don't want to use it for a core for my new one.
Old Mar 7, 2025 | 04:17 AM
zl1 camaro's Avatar
What is the part # I will call my buddy up @ gm to ck. I bet if you post the # somebody on this sight will also know..
Old Mar 7, 2025 | 04:59 AM
72455's Avatar
1972 U code Supreme
Where would I find the part #?
Old Mar 7, 2025 | 05:14 AM
zl1 camaro's Avatar
Originally Posted by 72455
where would i find the part #?
should be right on the top of the case around the top side where you would tighten the bolt after adjusting the belt.
Old Mar 7, 2025 | 05:22 AM
Original ALT part number should be stamped into the casing resembling image below...
Lots of threads/posts on this site demonstrating ALT part number locations & date codes...Search is your friend here.
Alternator Date Code
Old Mar 7, 2025 | 02:03 PM
72455's Avatar
1972 U code Supreme
I didn't see any numbers on the casing when I took it off, so I'm guessing it's not the original.
Old Mar 7, 2025 | 06:09 PM
joes_olds's Avatar
Pretty sure any Delco unit would have a part number stamped into it. They are also fairly easy to rebuild, especially if it was recently working and not sitting in the elements for a decade.
Do auto parts stores still bench test alternators for customers?
Old Mar 7, 2025 | 06:19 PM
72455's Avatar
1972 U code Supreme
Yup, but I have no idea what the part number would be, so there's no way to bench test it without the correct parameters.
Old Mar 7, 2025 | 06:20 PM
Yes
Old Mar 8, 2025 | 07:39 AM
72455's Avatar
1972 U code Supreme
I did see "10-3" stamped on the back of the casing.
Old Mar 8, 2025 | 07:45 AM
Sugar Bear's Avatar
A local rebuilder vs. a big box auto store is a much better option if that is an option for you. They'll often take your core even when upgrading to a different model.We have an old school one in town that is excellent, he personally tests and rebuilds the components.
Mar 3, 2025 03:05 PM
78Cutlass4Speed
Jun 30, 2024 10:33 AM
mmurphy77
Sep 5, 2013 08:33 PM
travisbeamon
Mar 5, 2013 10:47 AM
mefirst72
Aug 9, 2012 05:29 AM
