Need advice on shocks and springs
I have a 72 olds cutlass 442 with a 455ci motor was wondering what kind of springs and shocks are good on the market.dont want to go cheap but good ones.where is a good places to get them.
The front springs are matched to your car. The stock springs seldom need replacement and are correct for your car...
I usually leave them alone. I like progressive ratio springs in the back ...
What will your car be..? Daily driver, occasional drags, trailer queen ..?
Another place you can check for springs is Eaton Springs in Detriot. You can google them for their contact information. They have the blueprints for every American car since 1906, and can also customize your application if you want them lowered, etc. A quality product for a little more money but it's worth it.
KYB's and Monroe's are both good shocks so you won't go wrong with either.
STLBLUESBROTHER LET ME ASK YOU SOMETHING IF YOU GET A CHANCE CAN YOU TAKE A MEASURENMENT FROM THE GROUND TO THE BOTTOM OF THE FENDER WELL TRIM AND THE REAR FROM THE GROUND TO BOTTOM OF THE FEDER WELL TRIM.ON MY CAR THE FRONT SITS AT 25 INCHES AND AND REAR SITS AT 27 INCHES JUST WONDERING IF MY CAR IS SAGING THANKS.
The chassis service manual has all the carrying height specs if you have one, if not, get one.
I have the '71 442 specs?
With a full gas tank, correct tire pressure, empty trunk and measuring to the lowest portion on the outside edge of the rocker panel 1" rearward of the front door opening by the fender and 3 inches forward of the rear wheel opening the numbers are 9-13/16" and 9-11/16" respectively.
They do sit slightly lower in the rear (1/8") and lower than any other A body model, wagons are the highest.
RetroRanger
February 25th, 2014 05:04 PM
