Need advice on shocks and springs
Old Nov 30, 2009 | 09:55 PM
ELECMAN's Avatar
I have a 72 olds cutlass 442 with a 455ci motor was wondering what kind of springs and shocks are good on the market.dont want to go cheap but good ones.where is a good places to get them.
Old Dec 1, 2009 | 12:46 AM
oldsonharmont's Avatar
The Original Parts Group catalog has a thorough listing of coil spring applications for the Cutlass. I've also heard many here recommend the KYB Gas-A-Just shocks as well.
Old Dec 1, 2009 | 02:21 AM
Charlloots's Avatar
ill second that.
Old Dec 1, 2009 | 06:34 AM
mugzilla's Avatar
is Fast Enough ...
The front springs are matched to your car. The stock springs seldom need replacement and are correct for your car...
I usually leave them alone. I like progressive ratio springs in the back ...
What will your car be..? Daily driver, occasional drags, trailer queen ..?
mugzilla's Avatar
is Fast Enough ...
x3 ...
Old Dec 1, 2009 | 07:51 AM
ELECMAN's Avatar
the car would be used for weekend driving the car sits front and rear at 10 inches from the ground to the bottom of the rocker under the door is that what it suppose to sit at
Old Dec 1, 2009 | 11:21 PM
mugzilla's Avatar
is Fast Enough ...
I'd like to see the ride height specs myself ...
Old Dec 3, 2009 | 05:13 AM
OLD SKL 69's Avatar
GM Enthusiast
Another place you can check for springs is Eaton Springs in Detriot. You can google them for their contact information. They have the blueprints for every American car since 1906, and can also customize your application if you want them lowered, etc. A quality product for a little more money but it's worth it.
KYB's and Monroe's are both good shocks so you won't go wrong with either.
Old Dec 3, 2009 | 09:49 AM
agtw31's Avatar
i bought eibach(edelbrock) springs and shocks for our cutlass
the ride height was perfect(no sag),ride wasnt too firm or bouncy
i recommend them
Old Dec 3, 2009 | 10:28 AM
stlbluesbrother's Avatar
Moog makes a great GM (1968 - 72) replacement coil spring. I just had Moog springs and AC Delco shocks mounted all around.
Old Dec 4, 2009 | 09:53 PM
ELECMAN's Avatar
STLBLUESBROTHER LET ME ASK YOU SOMETHING IF YOU GET A CHANCE CAN YOU TAKE A MEASURENMENT FROM THE GROUND TO THE BOTTOM OF THE FENDER WELL TRIM AND THE REAR FROM THE GROUND TO BOTTOM OF THE FEDER WELL TRIM.ON MY CAR THE FRONT SITS AT 25 INCHES AND AND REAR SITS AT 27 INCHES JUST WONDERING IF MY CAR IS SAGING THANKS.
Old Dec 5, 2009 | 11:57 PM
mugzilla's Avatar
is Fast Enough ...
I've heard/read that they were supposed to sit lower in the back ...
Old Dec 6, 2009 | 04:22 AM
Bluevista's Avatar
Registered
The chassis service manual has all the carrying height specs if you have one, if not, get one.
I have the '71 442 specs?
With a full gas tank, correct tire pressure, empty trunk and measuring to the lowest portion on the outside edge of the rocker panel 1" rearward of the front door opening by the fender and 3 inches forward of the rear wheel opening the numbers are 9-13/16" and 9-11/16" respectively.
They do sit slightly lower in the rear (1/8") and lower than any other A body model, wagons are the highest.
Old Dec 6, 2009 | 08:02 AM
dc2x4drvr's Avatar
x100, and an Assembly Manual is a must for an Olds owner.
dave84
Suspension & Handling
Nov 14, 2012 08:17 AM
J-(Chicago)
Nov 7, 2011 08:19 AM
pcard
May 14, 2011 02:54 PM
DAN76
Oct 10, 2008 05:52 AM
