mounting bracket problems?
Old Mar 20, 2014 | 06:59 AM
86odls's Avatar
none of my brackets line up on my 72 350 and i replace belts about twice a month and it really sucks. what should i do?
Old Mar 20, 2014 | 07:03 AM
mrolds69's Avatar
You either have some wrong brackets or some wrong pulleys. You're going to have to check them all.
Old Mar 20, 2014 | 07:09 AM
455man's Avatar
There are letters on the pulleys. See if you can find them. The water pump pulley has like 3 different depths. Possibly someone switched it out. Maybe the wrong water pump was put on. There are 3 different lengths of them also.
Old Mar 20, 2014 | 07:31 AM
86odls's Avatar
my power steering pulley isnt lined up right with all the other brackets. and i heard if all the pulleys are exactly lined up the belt wont stay on, is this true?
Old Mar 20, 2014 | 07:40 AM
455man's Avatar
If the pulleys are not lined up it will throw a belt. There is a spacer on the PS bracket that might be missing. It goes on the side of the block. Maybe post a pic and someone might be able to spot something.
Old Mar 20, 2014 | 07:49 AM
mrolds69's Avatar
Yes...a pic from a few angles would help. The belts should be in a straight line if you are looking from either side.
Old Mar 20, 2014 | 08:43 AM
You have apparently failed to properly install the two spacers between the PS pump bracket and the block. One goes on the lower stud on the front cover and the other goes under the tab that bolts low on the side of the block. This is a common problem and a frequent question here. Search will turn up photos and diagrams.
Old Mar 20, 2014 | 08:52 AM
86odls's Avatar
yea ill try the spacer but if it is still uneven ill post some pics
Old Mar 20, 2014 | 09:37 AM
brown7373's Avatar
The lower PS bolt and spacer is hard to access and hard to see unless it's on a lift, and easily lost when the bolt is removed.
Old Mar 20, 2014 | 09:44 AM
Octania's Avatar
spacers- plural
Old Mar 20, 2014 | 10:25 AM
86odls's Avatar
Originally Posted by Octania
spacers- plural
thank you this is really going to help i have been looking for something like this for a while but couldnt find one
Old Mar 20, 2014 | 10:56 AM
455man's Avatar
Check out wild about cars. They have all these factory publications on the site. It's a really helpful place.
Old Mar 20, 2014 | 03:10 PM
You can also type power steering brackets into the search box on this site and get this thread, which has many photos and diagrams.
Old Mar 20, 2014 | 04:15 PM
mrolds69's Avatar
Inline tube has the spacer pair if you need them, they are on ebay. Maybe somebody here has them kicking around, too.
RAMBOW
Oct 2, 2024 07:56 PM
chasman414
Jun 25, 2020 07:05 AM
Bunser
Aug 31, 2019 04:35 PM
omg_its_nickels
Feb 16, 2010 11:13 PM
ctreutel
Jul 6, 2009 03:21 PM
