Master Cylinder Rebuild Service Supply Chain Problem..??
Old Oct 18, 2025 | 02:12 PM
11971four4two's Avatar
MOTORHEAD
There is a shop locally (BRAKE and EQUIPMENT) the does the sleeve rebuild on the 1 1/8 delco unit on our 1971. I was told they had no more "stock" to do any more.. May be 6 months or longer to get material needed.
Anyone in the know about this..??? Apparently his source had been OR is in AUSTRALIA
Old Oct 18, 2025 | 05:12 PM
dc2x4drvr's Avatar
White Post does impeccable work.
Old Oct 18, 2025 | 06:27 PM
MOTORHEAD
Brake and Equipment uses stainless sleeves
white post states brass sleeves on the site. may be a go to option..??
Old Oct 18, 2025 | 06:41 PM
Bummer.
I didn't know that inserts were used to rebuild master cylinders. I thought it was just a hone that was used like in a slave cylinder kit.
Old Oct 18, 2025 | 09:00 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It might be worthwhile to call Karp's.
Old Oct 18, 2025 | 09:24 PM
can you define that acronym as I have no idea what OR means in this context.
Old Oct 19, 2025 | 08:49 AM
MOTORHEAD
Originally Posted by Olds64
Bummer.
Brad showed me his stock a short piece stainless "tube"
Left from a LONG cylinder length... When they run low they order more...
The x-Man sells them The goods.. He has NONE and has not even placed and order 4 resupply yet... As of 17OCTOBER2025
He estimated at least 6 months... Close to when he plans to RETIRE from THE SHOP.
Bernhard
Brakes/Hydraulic Systems
Jul 2, 2024 12:57 PM
Kevin W
Jul 11, 2022 11:54 PM
MildBill
Jan 19, 2022 06:31 AM
Zr1bandit
Mar 18, 2020 07:52 PM
johnspd22
Jan 24, 2010 06:48 AM
