Which Manifold for a 455
Old Jun 5, 2011 | 10:55 PM
oldsguybry's Avatar
NOVICE car nut
I was wondering which exhaust manifolds to use for a 455 , the driver side one on my 72 CS 350 angles down , leaving the exhaust a little close to the ground. The 455 came out of a Toro so I cant use the exhaust manifolds that are on there....is there a specific code / serial number besides W Z to shorten my search on ebay or cl ? ..... I thought I asked this before , but cant seem to find that thread . Thanks in advance.
Old Jun 5, 2011 | 11:23 PM
oldsguybry's Avatar
NOVICE car nut
would the number happen to be LH "W" 402295 and RH "Z" 402294 ?
Old Jun 6, 2011 | 06:46 AM
Yes. You can also use the LH "X" 412287 manifold from the 1973-74 big block cars. This manifold has individual runners like the "W" manifold and was paired with the "Z" in 1973-74 applications. Note that there is another "X" manifold (389269) that was used on the 1965-68 cars. This early manifold will work but it does not have the individual runners that the later manifold has.
Old Jun 6, 2011 | 08:38 AM
oldsguybry's Avatar
NOVICE car nut
cool , thanks Joe
Old Jun 6, 2011 | 08:55 AM
oldsguybry's Avatar
NOVICE car nut
I seen a picture of the manifolds i mentioned and the one manifold seemed to have a strange angle on the exhaust port .....maybe it just looked odd in the pic
looked at the pic again and the driver side exhaust manifold seems to angle down and to the side a bit......there is not a whole lot of room between that and the frame where the lower A-frame hooks up....anyone ever have a clearence issue ?
Old Jun 6, 2011 | 10:56 AM
oldsguybry's Avatar
NOVICE car nut
Old Jun 6, 2011 | 11:35 AM
droptopron's Avatar
delete
That looks pretty standard for what I've seen. You may want to confirm what the outlet size is when you buy them. Some are manufactured with 2 1/4' which may be more desirable for you but isn't stock.
Old Jun 6, 2011 | 01:03 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Are your motor mounts all worn out?
Old Jun 6, 2011 | 01:28 PM
Those are correct for a 1969-72 A-body (Cutlass) and will fit 1964-1977 cars.
Old Jun 6, 2011 | 01:29 PM
oldsguybry's Avatar
NOVICE car nut
probably , I was going to take a bunch of pics of everything in about a month....when I get my other vehicle registered , then i can park the CS and dismantle it.
Old Aug 12, 2011 | 08:10 PM
extreme1's Avatar
Who makes these re-pops again?
Old Aug 12, 2011 | 09:01 PM
Thorntons
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
oregontopcat
Jan 31, 2014 06:31 PM
oregontopcat
Feb 28, 2011 12:11 PM
thomaswatk
Mar 22, 2007 01:31 PM
