Loose Carpet
Old Dec 15, 2023 | 07:27 AM
george@BWR's Avatar
Loose Carpet
I have a small area where the carpet is loose in my 1972 Olds Cutlass. I have tried double sided carpet tape but it will not stick to the floor of the car. If anyone knows a way to attach the carpet please let me know.
Old Dec 15, 2023 | 07:59 AM
chip-powell's Avatar
3M upholstery spray adhesive worked for me. Just make sure that the area is clean first.
Old Dec 15, 2023 | 09:11 AM
george@BWR's Avatar
Thanks for the suggestion. I wil give it a try.
Old Dec 15, 2023 | 09:14 AM
What section is loose? I can’t visualize where there’s the ability for the carpet to be loose.
Old Dec 15, 2023 | 09:16 AM
The carpet on the floor isn't glued down. It is molded and just sits there, retained by the door sill plates.
Old Dec 15, 2023 | 09:47 AM
I know. I had a small corner of my replacement carpet that I could not get tucked up under my rear seat (about 2"x2"). It was one of those things that only I ever noticed. But it drove me nuts anyway. A little of the spray adhesive took care of it nicely.
Old Dec 15, 2023 | 11:41 AM
george@BWR's Avatar
At the bottom of the rear seat it pulled loose where it tucks up under the armrest.
Old Dec 15, 2023 | 11:43 AM
george@BWR's Avatar
This is the carpet at the bottom of the rear seat. It pulled away from where it goes und the armrest.
Old Dec 15, 2023 | 01:24 PM
Cosmic Charlie's Avatar
I slipped a long plastic wire tie through the carpet edge where it could not be seen, and pulled it back toward the rear top seat base and attached it there ... worked fine for mine
Phoenix8990
Mar 22, 2021 08:00 AM
seanm12
Mar 13, 2021 05:47 AM
Toms cutlass
Dec 4, 2017 12:54 PM
dhartley72
Oct 29, 2010 05:29 AM
66ninetyeightls
Mar 14, 2010 10:32 AM
