How I kept myself amused today
Old May 5, 2013 | 08:26 PM
2Olds4U's Avatar
Majored in rear tire demo
Had a little extra time so I decided to to get on to stage 2 of the restoration. Worst part was the captured nuts that spun in the cages. Overall, not a bad time.
Old May 5, 2013 | 08:32 PM
Strong work.
Damn I'm jealous, I want a rotisserie.
Old May 5, 2013 | 08:35 PM
oldstata's Avatar
Justin
damn i'm jealous, i want a rotisserie.
x2
Old May 5, 2013 | 08:46 PM
HonestDave's Avatar
My last bolt on the 65 I'm pulling apart is spinning in the housing. Going to give it the sawz-all treatment this week and continue. Get me down to the frame and try to flog the chassis to a needy home. Must say, good exercise, just wish I'd started wearing gloves earlier.
Old May 6, 2013 | 04:02 AM
2Olds4U's Avatar
Ya gotta love those caged nuts. The front ones in the cowl that spun at least you can access. I popped the cage up and grabbed the nuts with a small vise grip. The rear-most ones are a different deal. Had to really get inventive.
Old May 6, 2013 | 04:29 AM
firefrost gold's Avatar
What are you going to do when you get after it
Old May 6, 2013 | 07:45 AM
HonestDave's Avatar
I might try wedging a big pickle fork in the back between the trunk bottom and frame member to jam the nut for my rear left. If that doesn't work, it's out with the saw. At least mine don't have to be saved. With yours, you likely have to cut the tops off the boxes to get at the nuts, sometimes, and then re-weld.
Old May 6, 2013 | 07:57 AM
oldolds88's Avatar
i use a hole saw to cut the top out and then put a metal plug in it.works quite well.
Old May 6, 2013 | 08:19 AM
HonestDave's Avatar
I like that. Seriously efficient, and neat as well.
Old May 6, 2013 | 08:26 AM
oldolds88's Avatar
the plugs i use are from the factory. we used the to plug the power ant hole when they were drilled in the wrong car.a couple of them were found among my dads stuff when he died.they are 1 1/4 around,and can be reused. it has a small strap in the center,hit the strap with a hammer and it will poke out on 2 spots to lock under the sheetmetal. just put a little sealer around the edge and whack. can get the in different sizes at most auto paint shops or dealer.
Old May 6, 2013 | 04:05 PM
2Olds4U's Avatar
Talking
I went at it a little differently. I wanted to make it as thought nobody did anything unorthodox. For the front, I used an air chisel to pop the cage up and grab the nut. Then I can just fold it back down and tack weld the cage back,
For the back, I used a cut off wheel to make a flap I folded up and got it that way. Then I can just fold it back down and mig it back. Nobody will ever know.
Nice to see different approaches to what is a common problem with these.
Dead Reckon
Mar 4, 2016 10:55 AM
bisscrac
Dec 17, 2014 11:28 AM
Tyler Padgitt
Jan 8, 2012 08:02 AM
UCF72Cutlass
Jun 16, 2008 04:06 AM
