Not sure what direction to go in, which would you do?
Old May 6, 2013 | 12:52 PM
speedaddict78's Avatar
Certified Car Crazy
Question Not sure what direction to go in, which would you do?
Got my '78 Cutlass.. stock 305. th350 trans. Stock rear.. Not sure of ratio, but it's probably a 2.41 peg leg..
The motor runs good for the most part. It's all original. Not sure of exact mileage.. But it's over 100k. Smokes a little bit on start-up.. Needs either valve seals or guides.. But it's not that bad. Hard to say if it burns oil b/c it leaks at the pan gasket/rear seal..
Trying to decide if I should focus on the motor.. I would like to leave the original 305, just have it rebuilt. Yeah, I know. 350...etc.. I've had a 406sbc and I know the power potential I am giving up.. Not that direction I want for this car.. When I do the motor, just .030 over, flat tops, vortec heads, intake,headers,mild cam... Nice cruiser motor..
Or.. leave the motor for now, just maybe do the heads.. I have an edelbrock intake I could throw on.. and I have shorty headers.. But I'm in no rush to do the headers b/c then I gotta replace the Y-pipe..
And do swap out the rear end.. I found a 3.73 non-posi local.. For $100. Or a 3.55 posi ( I think its an 8.5) for $400.
I don't take this car on the highway that much.. If I do, it's within a 10-15 mile trip.. But eventually I wanna do a 200-4r trans too.
So, Motor.. leave trans.. Leave rear..
Or Minor touches to motor, do rear.. ?
Old May 6, 2013 | 03:30 PM
HonestDave's Avatar
I, personally, would do as little as possible. I like to make things last as long as I can, within reason. If I was worried something was going to go soon, I'd hunt out a cheap parts car for $300-$500 that has a bunch of what I want. I'd strip it, or just hide it away until needed.
On the other hand, I've spent thousands of dollars on a car, and then sold it at a huge loss when I was tired of it, so how rich do you feel?
This is the fun part, you still have your money !!
Old May 6, 2013 | 04:17 PM
Rickman48's Avatar
The 3:55 would give you the best 'bang for the buck' at this point.
jag1886
Mar 17, 2018 12:12 PM
cutlass xombie
Aug 22, 2012 07:47 AM
sealw98
Feb 21, 2011 11:45 AM
olds59
Feb 19, 2009 04:38 PM
1BAD68"S"
Nov 9, 2006 04:30 AM
