Help with 1966 88 Front Disc Conversion
Hi Gentleman-
Thanks for your time and knowledge. I looking for advise on the easiest and most cost effective way to convert my 1966 Dynamic 88 drums to discs.
This was a option for 67 B bodies, but it seems difficult to find conversion kits for B bodies. Will the 67 parts bolt on 66 or are there spindle issues ect.
Regards-
JS
Regards-
JS
Hi Gentleman-
Regards-
JS
Regards-
JS
I've got a set in Oregon on a 1970 parts car. The downside that's been discussed is if a rotor gets too worn to turn again then finding a replacement rotor is really difficult. But if want to consider it I do have the complete setup. John
Maybe Joe can help confirm or correct. But I believe all you need to do is replace the master cylinder, brake lines from the master and the distribution block. Not sure, you may also have to replace the rod that goes from the booster into the master cylinder.
John
If you decide to stay with the drum brakes and just upgrade to the dual reservoir master cylinder that's not too difficult. The reason I say that is the 1967 had dual reservoirs and the 66-67 were similar in many ways. So you should be able to purchase the parts from a 1967 and add them to your car. Do you have power drum in the front now?
John
John
Mocephus
Oct 1, 2021 09:45 AM
68442Convertible
Brakes/Hydraulic Systems
Jun 8, 2016 08:15 PM
scubastever
Sep 24, 2010 11:33 AM
