Disc Brake Caliper Brackets for Disc Conversion
I am converting my front brakes from drum to disc. Can someone recommend a source for accurate caliper brackets? I know that The Right Stuff sells them, or perhaps makes them, and other sources appear to sell their brackets.
I assumed that all/most of the brackets are made in China, maybe at the same factory, so I bought brackets on ebay from the cheapest source. The right bracket cutout hits the caliper body when I try to slide it to the end of travel. I bolted the 2 calipers back to back for comparison and determined that one of the threaded caliper mounting holes on the right bracket is in the wrong location.
There is also a potential issue with both brackets. The 1/2" and 5/8" mounting holes are 1/32" over size - which I think means that the bracket will shift during braking. Maybe they are all made that way - has anyone else noticed this? By comparison, the mounting holes on my drum backing plates are a very snug fit. Otherwise, the brackets look well made and are of 1/4" thick steel.
Mocephus
Oct 1, 2021 09:45 AM
doc
Feb 8, 2012 10:49 AM
