Need help with this alternator brackets
Old December 9th, 2016, 12:25 PM
STLCRZY's Avatar
Need help with this alternator brackets,hope anybody have some mounting pictures, Not sure if it was from a 67.
thanks
STLCRZY is offline
Old December 9th, 2016, 01:04 PM
thanks
Looks like 67. What is the casting number on the cast bracket?
joe_padavano is offline
Old December 9th, 2016, 01:05 PM
2blu442's Avatar
Here's some pictures of a similar setup on a 1966 Cutlass. These are all on the engine, if its still not clear I'll look for some additional photos. John
2blu442 is offline
Old December 9th, 2016, 01:30 PM
STLCRZY's Avatar
don´t have the number at hand
STLCRZY is offline
Old December 9th, 2016, 01:32 PM
STLCRZY's Avatar
think a few more pics would be very helpfully....do i need four brackets?
STLCRZY is offline
Old December 9th, 2016, 03:15 PM
2blu442's Avatar
Do you have a power steering pump with the bracket behind the pulley? If you have that still attached to the power steering pump I think you only need the three brackets in your photos. John
2blu442 is offline
Old December 10th, 2016, 01:02 AM
STLCRZY's Avatar
i don´t get the power steering pump with this SB, the 3 brackets is the only what i have.
Any body have pics from service manual ?
many thanks
STLCRZY is offline
Old December 10th, 2016, 03:32 AM
STLCRZY's Avatar
looks like 67. What is the casting number on the cast bracket?
386216
d 3
STLCRZY is offline
Old December 10th, 2016, 07:01 AM
386216
d 3
According to the parts book, that bracket application is:
All 1965 V8 with A/C
1966-67 full size (not F-85 or Toro) with A.I.R. and without A/C
All 1967 V8 (except 400 or Toro) with A/C
1967 F-85 330 with A.I.R. and without A/C
Old December 10th, 2016, 01:17 PM
lemoldsnut's Avatar
Yes that is correct. As John pictured which is a car with A.I.R. which is the smog pump set up. it also came on cars with air conditioning. So one is not alternator but the back power steering pump bracket that goes from the intake to the head and supports the back of the power steering pump.
lemoldsnut is offline
Old December 10th, 2016, 03:16 PM
STLCRZY's Avatar
Problem solved.
Thanks guys
STLCRZY is offline
olddaz
August 27th, 2014 06:39 PM
2w-30s
April 21st, 2013 03:32 PM
Bronco Fan
April 10th, 2013 04:27 AM
ERIC27
March 3rd, 2013 11:14 AM
fbonanno
December 31st, 2012 05:44 PM
Quick Reply: Need help with this alternator brackets
