Head Bolts for Early vs the rest of the 350 builds
I have the heads back from the machine shop at a whopping $834 and while searching the many sites, a question came up. My engine is a 1968, and some of the listings are for 1/2" head bolts and some are 7/16" depending on whether mine is "early" or later. Now I don't have a micrometer and 1/16th of an inch is hardly noticeable with a ruler. What 350 was considered "early"? Secondly, does anyone have a good source of head bolts? I can only find them with Original Parts Groupso far and they are the ones that started the question 1/2" or 7/16". Any advice here would be appreciated as the freakin bolts are incredibly expensive and heavy to ship so I don't want to get the wrong ones etc. ARP is simply too expensive for street applications.
Every single Olds V-8 from 1964 to 1976 uses 7/16" head bolts. Every single Olds V-8 from 1977-1990 uses 1/2" head bolts. As usual, aftermarket catalogs have errors.
I'm shocked, SHOCKED I tell you...
I'm SURE you can get a set of original head bolts from someone on here for less.
I won't fault someone for spending $$$ on ARP hardware, but that kind of money for stock replacement bolts? yeesh. Post a parts wanted ad. Hell, I can probably scrounge together a set from my cobweb box.
I will take a look. I know that these are one use bolts so I would always worry about them if I bought some from a bin. When you are spending thousands for parts and machine work, $100 seems like a great deal
Rodney,
Am I wrong or are we supposed to replace the bolts when they've been torqued down and then removed? I remember reading somewhere about the tensile steel bolts and got it in my mind that they cannot be re-torqued with accuracy and sometimes go soft when you get to the triple digit torque specs. If I am wrong and we all agree you can re-use them, I'm interested for sure.
Chuck
Chuck
Rodney,
Chuck
Chuck
Newer motors use torque-to-yield bolts that are single use and must be replaced every time. Older motors like every Olds V8 ever built do not yield the bolts when torqued. They can be reused if not damaged.
Haha...then I have a set already in my throw away bucket..full of lifters and bolts. Strange how none of the sales places mention it! I am glad you cleared it up....I do not want to ever have to take the heads off again Thank you! Mine are the originals and I suspect have not ever been removed before...
stlbluesbrother
June 15th, 2012 08:45 AM
