Good way to remove painted lettering?
Old September 10th, 2009, 08:44 AM
scrappie's Avatar
Anybody have a good way to remove painted lettering on a Snap-On tool box. I have an old box with some less than desirable lettering on it and I want to remove. I have heard of some people using easy off oven cleaner, how does that work?
scrappie is offline
Old September 10th, 2009, 09:01 AM
IF the letters are painted on then you can probably use mineral spirits, or paint thinner to remove it. Hopefully it will only remove the letters and will leave the tool box paint in one piece.
Olds64 is offline
Old September 10th, 2009, 09:16 AM
Trying to remember member
wmachine's Avatar
Lacquer thinner, but be careful.
wmachine is offline
Old September 10th, 2009, 05:37 PM
Cameo White's Avatar
Smile
A bar of lava soap and a light touch? That's what an old sign painter who used to letter my dad's work truck used at times.
Cameo White is offline
Old September 12th, 2009, 08:40 AM
scrappie's Avatar
Just for you guys info, the easy off worked great. I sprayed a little on and let it sit a couple minutes and then wiped with paper towel and it started to come right off along with very little of the red snap-on paint. I did it about three times and it is all gone.
Thanks for the replies.
scrappie is offline
ATrain1
Non-Olds Engines
June 29th, 2012 12:58 PM
navvet
October 25th, 2011 07:25 PM
RATCHETMASTER
Brakes/Hydraulic Systems
October 20th, 2011 07:32 PM
Harmon
August 11th, 2011 09:25 AM
344870M
August 21st, 2009 08:04 AM
Quick Reply: Good way to remove painted lettering?
