Best way to remove lower ball joints
Old Aug 10, 2011 | 11:23 AM
Harmon's Avatar
I have a 80 olds cutlass with the lower control arms off the car. I got the bushings out, and now am taking a break from the heat....how might I tackle the lower ball joints? Does the joint press out through the bottom or top?
Old Aug 10, 2011 | 11:37 AM
RAMBOW's Avatar
Ben
should come out the top of the arm.
go to a local autoparts store and rent/borrow a balljoint press. Real easy.
Old Aug 10, 2011 | 01:05 PM
Lady72nRob71's Avatar
This should help you - similar arms...
https://classicoldsmobile.com/forums...tml#post290210
Old Aug 10, 2011 | 01:40 PM
Harmon's Avatar
Awesome Thanks!
Old Aug 10, 2011 | 06:28 PM
Um, actually you press on the top of the ball joint and the ball joints come out the bottom of the arm.
Old Aug 10, 2011 | 06:58 PM
Funkwagon455's Avatar
Oh, you are just not applying enough pressure!!!!
Old Aug 10, 2011 | 07:19 PM
Harmon's Avatar
so you push the lower joint out toward the ground as if the arm is on the car...correct?
Old Aug 10, 2011 | 07:21 PM
Yes.
Theoretically, the BJ could be removed with a few sharp blows on the threaded stud with a small sledge. However, a pipe fitting should be positioned under the control arm on the outside of the BJ to prevent damage to the arm.
Study up on this thread - operations are very similar.
https://classicoldsmobile.com/forums...end-job-2.html
Old Aug 11, 2011 | 09:25 AM
MX442's Avatar
Originally Posted by Lady72nRob71
Yes.
Never use a BFH to remove things that were "pressed" in! Things bend before the part gives. I learned this the hard way a long time ago as a teenager trying to remove ball joints. Had to spend the weekend looking for new spindles at the junkyard.
Use the proper tool! You can also use an air hammer to rattle it out, just don't gouge your A arms with it. But, you'll still need a press to put the new one in!
Gravy Waves
Dec 26, 2013 11:59 AM
russell-t
Aug 20, 2012 10:07 AM
ATrain1
Non-Olds Engines
Jun 29, 2012 12:58 PM
RATCHETMASTER
Brakes/Hydraulic Systems
Oct 20, 2011 07:32 PM
leepear
Jan 24, 2011 12:20 PM
