Generator light goes on and off
Old Oct 25, 2011 | 04:31 PM
oldsguybry's Avatar
NOVICE car nut
been noticing it for awhile now , it only goes on for a split second and then back off whenever I take my foot off the brake...... other then that the car starts fine , and the battery is about 1 year old and seems to be charged up good when I go to start the car...... I know it could be alot of different things , but anyone else ever have this issue ?
Old Oct 25, 2011 | 04:41 PM
Jetstar 88's Avatar
How old is the alternator/generator?
Old Oct 25, 2011 | 05:09 PM
oldsguybry's Avatar
NOVICE car nut
I would say about 7 years old
Old Oct 25, 2011 | 05:56 PM
Jetstar 88's Avatar
Then it could be that. My alternator of uncertain age does the same thing. Of course, it could be a short in the wire for the light, or even the instrument cluster itself.
Old Oct 25, 2011 | 06:45 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Could it be a loose connection on the small back post?
Old Oct 25, 2011 | 07:04 PM
Or a loose under-dash connection that moves when you press the brake pedal...
Old Oct 25, 2011 | 07:10 PM
AZ455's Avatar
1974 DELTA 88
I had an odd issue with the GEN light. Do your other lights on the instrument cluster work? I had a fuse that was blown, but tested good, the filament was just barely completing the circuit at the break (enough for an ohm meter), but could not carry the amperage needed for the circuit. The GEN light did weird things until I replaced it.
Old Oct 25, 2011 | 07:49 PM
oldsguybry's Avatar
NOVICE car nut
thanks guys , yea the instrument cluster guages work , ill have to do some detective work this winter while im fixing everything else...... I can almost hear voices telling me to just rip the whole car apart , but then id be walking to work
Old Oct 25, 2011 | 09:34 PM
Put a voltage gauge on it, and check just how much that brake light circuit is bogging the system down. It shouldn't be much.
Old Oct 26, 2011 | 04:31 AM
Chesrown 67 OAI's Avatar
Alternator could be at very low output at idle and when you apply the brake, the added current draw from your brake lights could take it into discharge, and then back to charge when you release the brake! Good way to test that is to brake it with left foot, then push on the gas pedal and see if "idiot" light goes out when RPMs rise! My bet is this is your problem and changing the alternator will be in your future!!
Old Oct 26, 2011 | 03:25 PM
oldsguybry's Avatar
NOVICE car nut
hit the nail right on the head , i beleive it only does this at night when my lights are on and im coming to a complete stop ..... did not think of that till now.
Old Nov 29, 2011 | 05:23 PM
oldsguybry's Avatar
NOVICE car nut
I thought I would add ..... while sitting in my car running in park with the heater on I noticed the gen light flashed on and off real quick the second I shut the power to the heater off .... that seems kind of strange that it would do that when im cutting the power off
Old Nov 30, 2011 | 10:55 AM
oldsguybry's Avatar
NOVICE car nut
455 heads
I did not want to start another thread just for this little bit of info , after finding out where the stamping for the head ID was I went to my moms house to see which ones I have ..... and they would be " C " heads , these are decent heads right ? I may have to sell the 455 and get another one later on , because of money
Old Nov 30, 2011 | 11:11 AM
Lady72nRob71's Avatar
Put a voltmeter across the battery. Should read a min. of 13.5V at idle, heater fan on high and lights on. 14-15 is right on.
Old Nov 30, 2011 | 11:48 AM
oldsguybry's Avatar
NOVICE car nut
I got an old volt meter laying around , I will check that out when the time comes .... thanks
72 cutlass455
Oct 21, 2010 06:25 AM
ej69
Jul 21, 2010 04:48 PM
Kidcutty
Feb 11, 2010 06:52 PM
Dkrone
May 1, 2009 08:39 AM
