Fuel lines...
Old Apr 16, 2010 | 07:19 AM
Eddie Hansen's Avatar
Fuel lines...
Ok I have a cutlass 69 vert, I was looking at all the lines fuel and brake and replacing them with stainless, now I replaced the main fuel line over 10 years ago, ( the body has been off that long!!) but looking at it there is no 1/4 return line and I can not remember if there was one? did all 69's have a return line? mine was a 350 car, I am sure i would have ordered it when I ordered the main line but looking in the garage I don't see it? and it has been so long I can not remember, and digital cameras were not an option back in the day LOL...
just asking if I need to get a return line, I am replacuing the 350 with a 455.
any advice would be appreciated
Old Apr 16, 2010 | 10:59 AM
Don L/442's Avatar
My friends 69 vert with a 400 has a return line and a non-vented cap.
My 69 hardtop with 455 has a return line but is plugged off and a vented cap.
CM states all A,B and C body cars with V-8 have return lines.
My 69 fuel pump does not have a return but my friends does so I guess it depends on your fuel pump and how you want to vent your tank and type of fuel pick up you have.
Old Apr 16, 2010 | 12:24 PM
Hmmmm
Thanks For the Info Don, I looked at the assembly manual and it appears to show both ways with and without a vent line? mine had this plastic two prong fork looking thing, but I am now upgrading to a 455? and I think the new fuel pump has a vent line fitting? not sure, Oh Geez... well I will probably change the tank and the pickup anyway is there any benefit to having a seperate return line?
Old Apr 17, 2010 | 02:36 AM
Yellowstatue's Avatar
The return line is to prevent vapour lock when the temps are high...so if the body is still off put the return line in and decide later...the tank pick-up will have a second fitting if you want to go that way...and get the fuel pump to match the pick-up...two lines or single line...
Old Apr 17, 2010 | 12:01 PM
thanks..
Yes I think that is the safe route too, just get the pickups and pump to match the lines.. seems all the "big Block" cars had em and it is so much easier to do now.
cheers eddie
gearhead1218
Aug 10, 2010 08:18 PM
KZ442
Mar 15, 2010 09:24 PM
69Rman
Feb 26, 2010 05:10 AM
oldzy
Jan 29, 2010 06:06 PM
Charlie_brown
Sep 29, 2009 04:01 PM
