Fan and clutch clean up / Restore
Old Mar 27, 2022 | 08:54 PM
tkcutlass's Avatar
Planning on taking the fan off and blasting it, then painting it.
What's the best way to refresh/test the fan clutch.
Can the clutch be degreased and blasted or will that damage it, what's the best coating once it's prepped.
Old Mar 27, 2022 | 09:47 PM
Inline's Avatar
I blasted my clutch from Electra with crushed glass, it wont damage rubber parts ( shaft seal). Came out great, didnt give it any paint etc, left it as it was after blasting.
Old Mar 28, 2022 | 06:42 AM
tnswt's Avatar
'70 4-Speed W Machine
If you blast the fan don't use an element that is too abrasive as it will damage the metal. As far as the clutch, work on it with a plastic bristle brush, a little hot water and Simple Green, rinse sparingly with clean water. If you have a sealed unit the water will not affect it; however, if the clutch is leaking submerging it in water is not the thing to do. The finish is golden cad I believe, and you want to try and retain that finish if possible. Of course, if your clutch needs a rebuild, I'd ship it off as is, and let the rebuilder do the work since that will be covered in the price. Hope this helps.
Old Mar 28, 2022 | 08:01 AM
If the clutch is leaking you need a new one.
Cutlass71s
Sep 5, 2022 05:08 AM
tnswt
Feb 23, 2021 03:49 PM
jpc647
Dec 16, 2016 06:21 AM
My2nd 69 442
Dec 1, 2016 11:23 AM
toymobile
Jul 7, 2015 06:55 AM
