Fan Clutch Replacement
Old July 15th, 2017, 06:55 PM
Cutlass71s's Avatar
Hello, any tips when replacing a fan clutch on a 71 cutlass 350?
Thank you,
Peter
Cutlass71s is offline
Old July 15th, 2017, 07:16 PM
Are you asking for how to do this, or what kind of fan clutch to buy?
Allan R is offline
Old July 15th, 2017, 07:33 PM
jaunty75's Avatar
There's only one way to do it.
jaunty75 is offline
Old July 15th, 2017, 10:36 PM
wifespain's Avatar
screwdriver, and a 1/2 inch wrench, lol!! jam screwdriver between studs so it wont turn on u
wifespain is offline
Old July 16th, 2017, 04:57 AM
Cutlass71s's Avatar
Thank you, advice on how best to replace. Below is what I ordered from summit:
Old July 16th, 2017, 06:24 AM
Undo the 4 nuts that hold the clutch to the water pump. Remove fan/clutch assembly. Remove fan from clutch and install on new clutch. Make sure the fan goes on the same orientation that it came off. Torque bolts tight. Install new assembly and nuts to water pump threads. Tighten nuts.
Allan R is offline
Old July 16th, 2017, 06:58 AM
I'll just add one tip to Allan's writeup. I've had issues with the clutch being stuck on the water pump shaft due to rust. I apply a light coat of anti-seize to the shaft before sliding the clutch into place. Makes it easier the next time.
joe_padavano is online now
Old July 25th, 2017, 06:35 PM
Cutlass71s's Avatar
Unhappy
Super easy replacement, thank you for the help.
Old September 5th, 2022, 01:44 AM
Robcert42's Avatar
Have a 72" 350, one of the fan blades broke in half and have to replace it, have one on order. When you did your repairs did you have enough room just by removing the fan shroud or did you have to drop the radiator out too?
Thanks.
Robcert42 is offline
Old September 5th, 2022, 02:50 AM
'72 Cutlass ragtop
70sgeek's Avatar
Should clear without having to remove the rad - the shroud will have to come off but I know on my '72 350, I have to unbolt it first and then pull it out along with the fan/clutch assembly at the same time - not enough room to wiggle the shroud out by itself with fan and clutch still in place.
70sgeek is offline
Old September 5th, 2022, 05:08 AM
Remove the radiator top plate to allow it to tip forward. The issue is one slip of the wrench will turn a 1 hour job into a week or more depending on what you need to do to overcome a hole in the radiator core.
oldcutlass is online now
RandyS
July 6th, 2021 07:45 PM
Bee Saint Louis
July 5th, 2019 08:58 PM
47 Convertible
April 3rd, 2014 07:56 AM
RandyS
March 8th, 2014 05:07 AM
esisson
May 20th, 2008 12:09 PM
Quick Reply: Fan Clutch Replacement
