Exhaust smell in car
Old April 16th, 2023 | 02:10 PM
herkguy's Avatar
So I had an exhaust smell that would come in when the windows were down driving. As much as I like some 100LL smell, I didn't want to smell like it after I got done driving. I was looking at my trunk seal and it was soft so I adjusted the latch, not much change.
I then added some foam tape to see if it was crushing down and it stopped the smell.
Ordered a new seal and of course I figured out the issue after it showed up. I couldn't see the tree in the forest when i was trying to figure it out...bangs head. The original had been installed incorrect...lol
After I pulled it out, I compared it to the new one and although slightly different I installed the new one. Even after checking the old one when installed correct position, thought maybe it had been squashed a little in certain areas.
Anyways I hope it fixes the issue, snowing again so I can't test it today.
Check your seal if you get the smell with windows down...ugh
incorrectly installed seal
used seal flipped position
New Seal
Old April 16th, 2023 | 02:25 PM
Oldsguy's Avatar
Past Administrator
Yeah, pictures make it so evident, I had to double take though from the first one to the second and third.
Old April 16th, 2023 | 03:21 PM
70W-32's Avatar
Besides the seal, your motor is probably tuned too rich
Old April 16th, 2023 | 05:11 PM
Funkwagon455's Avatar
I can appreciate the sweet aroma of 100LL as well, but alas (NOT-GOOD!!)😄😳
Old April 16th, 2023 | 06:10 PM
I hope the new seal works well. Where did you get the new trunk seal and what kind of Oldsmobile do you have?
Old April 16th, 2023 | 06:47 PM
herkguy's Avatar
Could be, ill be tuning it up again soon, it does use some oil. know the valve stem seals stick which could be part of it. I found it was rebuilt with the rubber seals when i popped off a valve cover.
Old April 16th, 2023 | 06:49 PM
herkguy's Avatar
its a 70 442, bought it from the motor company.
oldsonharmont
Drivetrain/Differentials
April 19th, 2023 06:04 AM
bigrbandit
January 30th, 2019 05:55 PM
cus
June 16th, 2017 12:30 PM
Inline
Body work
May 1st, 2016 09:52 PM
Inline
Body work
March 31st, 2016 10:18 AM
