Exhaust Options for 67 Cutlass
Old Jan 31, 2024 | 08:17 AM
Taz54904's Avatar
I am looking for recommendations for dual exhaust for my 67 Cutlass Holiday Coupe. It has a 330/2-barrel. I didn't have much success looking online for a bolt on kit that goes to the exhaust manifolds. Seems like most were kits that bolt to headers, which I am not planning on putting on. Since it's the low HP motor I was thinking of 2" or 2 1/4" pipes. I plan on using Magnaflow mufflers on the exhaust.
I am also debating on having a local muffler shop make an exhaust vs me buying a bolt on kit.
Thx!
Old Jan 31, 2024 | 08:30 AM
alain's Avatar
Try Gardner Exhaust.com you may find what you are looking for
Alain platinum 442 4spd A/C
Old Jan 31, 2024 | 09:02 AM
zl1 camaro's Avatar
Thx!
Gardner exhaust the best of the best. but BIG $$$$$$
Old Jan 31, 2024 | 09:05 AM
It's always a good idea to stop by a local shop and get a quote.
Old Jan 31, 2024 | 09:46 AM
Taz54904's Avatar
I did send them an inquiry. The guy did say in the reply that they can build a show quality exhaust. I will probably call him just to know for sure but it sounds like it's going to be too pricy for what I'm doing with my car.
Old Jan 31, 2024 | 09:49 AM
Oldsmaniac's Avatar
See if Classic Exhaust is still around. I think they are in Ohio. They sell bolt on kits and sell on Ebay.
Old Jan 31, 2024 | 09:51 AM
Why do you need a show quality exhaust? I used my local muffler shop and he fabricated a complete true dual 2.5 inch exhaust for a reasonable price from headers to the rear bumper. Used aluminumized pipe and dynomax mufflers.
Old Jan 31, 2024 | 09:52 AM
zl1 camaro's Avatar
I have there exh on my car [stainless] 66 442 $1800.00
Old Jan 31, 2024 | 09:55 AM
Taz54904's Avatar
I don't need or want a show quality. I was just sharing what the guy from Gardner Exhaust sent to me. It's definitely not what I need for my car. Aluminized pipe would be perfect for me. I'll get ahold of a local shop, too, and see what they have to say. Thx!
Old Jan 31, 2024 | 09:58 AM
Taz54904's Avatar
Yup, they are still around. In fact, I had saved one of their exhaust systems in my "Watchlist" on Ebay but I didn't pay attention to the Seller's name until you mentioned them. Thx!
Old Jan 31, 2024 | 09:59 AM
Andy's Avatar
I had Waldron exhaust make me a factory correct exhaust, not stainless. it fit prefect. It was for my 1966 442. Was around 700.00 Waldronexhaust.com
Old Jan 31, 2024 | 02:31 PM
Taz54904's Avatar
UPDATE:
I'm going to have a local exhaust shop install an exhaust for me. From what I have read (here and other Cutlass sites) is considering that I have a 330 2-barrel and no intensions of making it "high performance" I don't need to go any bigger than 2 1/4" pipe.
Old Jan 31, 2024 | 08:01 PM
69CSHC's Avatar
Real headers are a pain in the butt. I had a nice set installed on my 67 330, with 2.5 inch custom pipes going to Flowmaster 2 chambers. Car sounded incredible. I received more praise and attention for the exhaust than the car. And the car was a real looker... All new suspension front and rear, lifted. Car still bottomed out with the long tube headers. From pipe crushes, to collector flange scrapes. Leaks here and there, cooking the starters, etc. I knew her like the back of my hand, drove her for parts of 3 decades. It didn't matter how careful I was, all my familiarity and she still gave me agida with exhaust issues.
Old Jan 31, 2024 | 09:30 PM
Sugar Bear's Avatar
IIRC, HC 455 4bbl factory dual exhaust options were 2 1/4" in '68? You definitely don't need anything bigger than that on a 330 2bbl. 2" would be fine if fitment is an issue.
Old Feb 1, 2024 | 12:54 AM
fleming442's Avatar
Bolt on parts rarely actually bolt on as designed. Pypes and Ram Air Restoration both make down pipes that will connect the manifolds to an A body exhaust kit. Otherwise, take it to a shop, and let them bend one.
Old Feb 1, 2024 | 04:32 AM
UPDATE:
Excellent! Show us a pic or two when you get it installed.
Old Feb 1, 2024 | 04:43 AM
Oldsmaniac's Avatar
http://classicexhaustinc.com/
Old Feb 2, 2024 | 02:50 AM
Taz54904's Avatar
I'll definitely share a pic or two once it's installed. I live in WI so I'm waiting for the snow and salt to clear the roads before driving over to the muffler shop.
Old Feb 2, 2024 | 05:21 AM
If you are using the stock manifolds they will need to fab or buy a crossover blockoff plate.
Old Feb 2, 2024 | 08:11 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Waldron is very good. On that car, I would probably pick my mufflers and go to a local shop if you have one and let them make the exhaust. I have had very good luck with two different shops. I used Waldron on the 54 Olds I had because it had power steering and the left side had some crazy bends. It fit perfectly. You can buy theirs with or without mufflers.
Old Feb 2, 2024 | 11:22 AM
Sugar Bear's Avatar
Start soaking the 6 exhaust pipe to manifold bolts repeatedly. An exhaust shop will use a hot wrench but everything done now to loosen them reduces the chance of a broken bolt or damaged manifold. Also put penetrating oil on the heat riser valve shaft if equipped..
You could also source new quality replacement bolts now so it gets "the good stuff".
If you can, please post a video/audio clip of the results and let us know which mufflers were used.
Old Feb 2, 2024 | 12:20 PM
Taz54904's Avatar
I'm with ya. I discussed this with the shop the other day. They will be making a plate so it'll be a true dual exhaust.
I bought two Magnaflow mufflers that the local muffler shop has agreed to use when then bend up my exhaust.. I slapped one on as a single exhaust and I like the sound of it.
I'll definitely post a video. Since I'm in WI, it'll probably be late Feb or early Mar, depending on the weather.
442man$
Vista Cruiser & Wagons
Oct 23, 2022 05:09 PM
brianbeez67
Mar 13, 2022 06:24 AM
Drews67Cutlass
Feb 28, 2020 11:51 PM
olds01
Sep 18, 2019 05:33 AM
30-A rider
Ninety-Eight
Feb 27, 2011 04:58 PM
