Electric Fans
Old August 24th, 2014, 06:53 PM
jag1886's Avatar
Electric Fans
Well it has finally cooled off here in Boise so I could work on the car a little. I got the Derale fans to fit this weekend, man it was total PITA to get these in the car, I was lacking a 1/2" of clearance to get them in.
It took 2 days of work to come up with 3/4" of space to get the fans in and still have a 1/4" of clearance. I had to modify the radiator support "it had been welded up crooked from the factory" had to move the air conditioning condensor forward a little to get the radiator moved forward, had the modify the front of the water pump a little and make button head bolts for the pulley. The fan set up fit the radiator almost perfect, it was the right height and the width was also right on, had to mount the fan assembly to the radiator and put it all in as a unit.
It looks good and should work well. I would not recommend this set up to other people unless you have a lot of tools and are willing to put in a bunch of hours to get everything right.
Now I can start wiring the new 150 Amp alternator and installing the Painless wire loom for the fan control.
jag1886 is offline
Old August 24th, 2014, 07:50 PM
47 Convertible's Avatar
Remind me again, you changed over to electric fan(s) why? Not being critical as I'm a great fan (bad pun) of electric driven fans. I had a lot of the same problems with fitment on my 1936 and 1947 project cars as you had. It is just a function of modifying from factory to something else. Hang in there. I hope it all turns out well.
Jerry
47 Convertible is offline
Old August 25th, 2014, 06:03 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
At least you put in the best aftermarket fans in, supposed to perform very well and US made. Their controllers are complete junk, wires pull out of connectors really easy. Factory fans from the Dodge Intrepid and Stratus fit with room to spare and move a good amount of air. My Stratus fans work well and fit my G body rad near perfect, just needed custom mounting straps which I attached to my top rad plate, come out as one now.
olds 307 and 403 is online now
1971 442 convert
October 23rd, 2012 07:50 AM
Axeni
November 26th, 2010 09:51 PM
Wyze
September 10th, 2010 01:07 PM
chris83
June 13th, 2009 08:16 PM
oldjunk
May 1st, 2009 03:10 AM
Quick Reply: Electric Fans
