drop spindles of f body spindles
Its not the least expensive way to go but the AFX spindle is the cats Meow for a-body suspension. I was not will to spend that much so I went with the stock spindles and tall ball joints. This gets you 75% of the geometry the AFX gets you without all the expense.
You also have to use 17" or larger wheels to run the AFX spindle because it uses Corvette hubs.
Murco
Brakes/Hydraulic Systems
March 7th, 2013 11:50 AM
69oldsdelta88
May 8th, 2009 02:33 PM
