drop spindles of f body spindles
Old Oct 9, 2011 | 09:53 PM
rogiestone's Avatar
Anyone running drop or f body spindles with coil overs? What are the real draw backs or advantages to either?
72 big block
Old Oct 10, 2011 | 07:31 AM
gearheads78's Avatar
car guy
72 big block
It was state of the art technology in 1988. Today not so much. There is bump-steer issuses when doing this on an A-body and the drop spindle geometry is terrible. There is a great modern book out called How To Make Your Muscle Car Handle. It does a really good job showing you pro and cons of parts ava today.
Its not the least expensive way to go but the AFX spindle is the cats Meow for a-body suspension. I was not will to spend that much so I went with the stock spindles and tall ball joints. This gets you 75% of the geometry the AFX gets you without all the expense.
You also have to use 17" or larger wheels to run the AFX spindle because it uses Corvette hubs.
Old Oct 18, 2011 | 06:11 PM
rogiestone's Avatar
do you know if there is any clearance issues from running tall ball joints when shimming the control arms on a 72 big block?
kurt7780
Suspension & Handling
Dec 2, 2019 08:18 AM
Murco
Brakes/Hydraulic Systems
Mar 7, 2013 11:50 AM
jayleo_4
Feb 20, 2012 05:25 PM
The Stickman
Jun 8, 2011 12:10 PM
69oldsdelta88
May 8, 2009 02:33 PM
