Does anybody know?🤔
The group number designates what the part is used for .
Turn signal flashers are in group 2.892 .
Hazard flashers are in group 2.575 .
You didn't specify which flasher you were talking about , so I gave you info about both .
www.gmpartswiki.com is your friend. You can take the number and reference is against legacy numbers on Rock Auto if you'd like, or you can search for the NOS part on eBay. The turn signal flasher is in the dash to the left of the steering column if you're sitting in the seat. The emergency flasher is in the upper left corner of the fuse block under the dash.
No, not in the GM parts book.
There may be cross references to those numbers in an aftermarket manufacturer's parts book .
68RocketAction has made the parts books available to all of us as a free download .
Thru 1975 - Oldsmobile Illustration Catalog - ClassicOldsmobile.com
Thru 1975 - Oldsmobile Chassis and Body Parts Catalog - ClassicOldsmobile.com
Use the illustration book to find a group number and then go to that group in the parts catalog to find the part number for your year and model .
If you look up a flasher on any parts store web site, the listing shows one part with "turn signal / hazard flasher" as the description.
I never yanked the key buzzer, but that seat belt buzzer was awful. Then I had a hard time finding one to replace it, Now it’s music when I go for a run, first the key buzzer, then borlas, then the seat be,t buzzer, then t tops off, no radio. Who’d a thought.
