Does anybody know?🤔
Old Nov 8, 2021 | 04:16 AM
72455's Avatar
1972 U code Supreme
Does anybody know?🤔
Looking for a factory correct OEM flasher for a spare for my '72 Supreme. Is part #6450089 correct?
Old Nov 8, 2021 | 06:21 AM
Burd's Avatar
What does it say in the parts book?
Old Nov 8, 2021 | 09:57 AM
Charlie Jones's Avatar
Phantom Phixer
In the 1972 Olds parts book it lists # 383627 as the flasher for turn signals in group 2.892 .
It lists # 3883794 as the hazard warning flasher in group 2.575 .
I found # 6450089 in GM parts wiki , and it fits 1980's models .
Old Nov 9, 2021 | 08:59 PM
72455's Avatar
1972 U code Supreme
What's the difference in the "groups"?
Old Nov 10, 2021 | 05:25 AM
Phantom Phixer
The group number designates what the part is used for .
Turn signal flashers are in group 2.892 .
Hazard flashers are in group 2.575 .
You didn't specify which flasher you were talking about , so I gave you info about both .
Old Nov 10, 2021 | 05:45 AM
72455's Avatar
1972 U code Supreme
So are there two separate flashers?.
Old Nov 10, 2021 | 06:24 AM
BackInTheGame's Avatar
Yep, two distinctly different flash modules. One mounts to the fuse block, the other is up under the dash, nearer the steering column.
Old Nov 10, 2021 | 06:33 AM
72455's Avatar
1972 U code Supreme
Oohhh...I didn't know that. So now I need to look for two spares. Numbers anyone?
Old Nov 10, 2021 | 06:39 AM
Phantom Phixer
Turn signal 383627, hazard flasher 3883794 .
Old Nov 10, 2021 | 07:12 AM
72455's Avatar
1972 U code Supreme
Thanks...and are there cross references?
Old Nov 10, 2021 | 08:01 AM
WTHIRTY1's Avatar
Escape From The Ordinary
www.gmpartswiki.com is your friend. You can take the number and reference is against legacy numbers on Rock Auto if you'd like, or you can search for the NOS part on eBay. The turn signal flasher is in the dash to the left of the steering column if you're sitting in the seat. The emergency flasher is in the upper left corner of the fuse block under the dash.
Old Nov 10, 2021 | 08:04 AM
Phantom Phixer
No, not in the GM parts book.
There may be cross references to those numbers in an aftermarket manufacturer's parts book .
68RocketAction has made the parts books available to all of us as a free download .
Thru 1975 - Oldsmobile Illustration Catalog - ClassicOldsmobile.com
Thru 1975 - Oldsmobile Chassis and Body Parts Catalog - ClassicOldsmobile.com
Use the illustration book to find a group number and then go to that group in the parts catalog to find the part number for your year and model .
Old Nov 10, 2021 | 09:28 AM
72455's Avatar
1972 U code Supreme
Do the turn signal flasher and hazard flasher function differently, or would the same part number work for both?
Old Nov 10, 2021 | 11:00 AM
WTHIRTY1's Avatar
Different part numbers, different function.
Old Nov 10, 2021 | 11:12 AM
72455's Avatar
1972 U code Supreme
Marvelous...this just got more complicated 😒
Old Nov 10, 2021 | 11:41 AM
Yes, they should be interchangeable. I worked in auto parts stores in high school / college and as long as the prongs were the same orientation the flasher units were interchangeable.
If you look up a flasher on any parts store web site, the listing shows one part with "turn signal / hazard flasher" as the description.
Old Nov 10, 2021 | 05:40 PM
72455's Avatar
1972 U code Supreme
I keep coming up with SF552 and 6450089 as cross reference part numbers...does that sound right?
Old Nov 10, 2021 | 06:49 PM
You won't know if they sound right until you install them. 😁😛🤣
Old Nov 10, 2021 | 07:24 PM
72455's Avatar
1972 U code Supreme
Ha ha Norm...good one!🤣🤣🤣
Old Nov 10, 2021 | 07:42 PM
One of the listings I saw on a parts web site had “Loud” in the notes section.
Old Nov 10, 2021 | 07:57 PM
I'm just waiting for modern cars to replace the click with some sort of Bitchin' Betty.
Old Nov 11, 2021 | 08:06 AM
Burd's Avatar
Don’t forget the key buzzers too. They are harder to find, because we all yanked them back in the day.
seat belt buzzers too. Lol.
Old Nov 11, 2021 | 08:25 AM
72455's Avatar
1972 U code Supreme
I had one but never installed it..lol. Sold it to someone who was willing to put up with the noise.😀
Old Nov 11, 2021 | 08:28 AM
Burd's Avatar
I never yanked the key buzzer, but that seat belt buzzer was awful. Then I had a hard time finding one to replace it, Now it’s music when I go for a run, first the key buzzer, then borlas, then the seat be,t buzzer, then t tops off, no radio. Who’d a thought.
Old Nov 11, 2021 | 11:25 AM
rocketraider's Avatar
Oldsdruid
It's usually mounted in a clip that can leave you with bloody fingertips if you're not careful...
Old Nov 11, 2021 | 12:27 PM
72455's Avatar
1972 U code Supreme
Hopefully it won't come to that..lol. I'm just stocking up.
Old Nov 11, 2021 | 12:40 PM
Burd's Avatar
I just looked, I dont have any flashers , just a horn relay 😵‍💫
but that’s another to have in hand.
Old Nov 11, 2021 | 01:55 PM
72455's Avatar
1972 U code Supreme
True that...I have an OEM now,, but a spare never hurts.
Old Nov 11, 2021 | 02:01 PM
Burd's Avatar
Now I’m looking for both flashers 🤣
Old Nov 18, 2021 | 11:41 AM
72455's Avatar
1972 U code Supreme
I decided on two of these...I'll test them when I get a chance.
Nov 6, 2021 07:11 PM
oldsmobilty
Aug 3, 2014 05:02 PM
ragtop olds
Jun 7, 2012 03:49 PM
4424me
Care and Appearance
48
Mar 7, 2012 04:45 PM
Chumley
Nov 20, 2011 02:54 PM
