D-shaped PVC & Breather Grommets- ANyone have napa Pn's?
Old Dec 26, 2013 | 02:26 PM
RAMBOW's Avatar
Ben
I need to pickup a new set of PCV & valve cover breather gaskets for a new set of valve covers- these are the D-shaped stock style. The online catalog for Napa doesn't list them if you search on 1970 or 1966 oldsmobile 442 as your application... but if i remove the vehicle and just search "pcv grommet" i see several that may be close.
Does anyone happen to have NAPA Pn's jotted down for the right ones?
Thanks!
Ben
Old Dec 26, 2013 | 02:58 PM
Octania's Avatar
GM 22532566
no luck today at gmpartsdirect.com
Napa 630-1052
63/64" round ID for PCV filter canister 1969+
For pcv vlave I have only
385283
"GROMMET, valve cover, for PCV valve, all Olds V-8
ID 7/16"
HELP! Brand # 42314 might be same
NON-GM WILL NOT WORK RIGHT- rubber too hard!
That last line was my experience, YMMV. No way was the PCV valve going in that HELP brand chinese POS
Old Dec 26, 2013 | 03:58 PM
billmerbach's Avatar
major noob
I have one or two laying around no rips or tears
Old Dec 26, 2013 | 04:42 PM
Fusicks has them.
Old Dec 26, 2013 | 10:27 PM
RAMBOW's Avatar
Ben
Thanks guys... I'll do some more looking.
I have a counter guy at my local napa who will likely order in all the possible ones and let me pick out the right ones... I was just hoping not to make him do that.
Fusicks has them.
Fusicks wants $10 each for them plus their usual $25 shipping charge for a couple items that could go in a $5 flat rate padded envelope, so I'm trying to avoid that.
Plus the fusick one I ordered 2 years ago split almost immediately, so hoping to find one made by a different mfg anyway.
Old Dec 27, 2013 | 07:01 AM
RandyS's Avatar
The Parts Place has them for $8.00, and their shipping is cheaper than Fusicks. I ordered a couple and they look real good.
Old Dec 27, 2013 | 07:42 AM
11971four4two's Avatar
MOTORHEAD
NOE 6301074 napa part number
http://www.napaonline.com/Catalog/Ca...074_0417240032
Old Dec 27, 2013 | 08:38 AM
RAMBOW's Avatar
Ben
here is my initial list:
NOE 6301364 - PVC Grommet- Support Wedge- .42" ID 1.71"OD http://www.napaonline.com/Catalog/Ca...364_0417215202
NOE 6301043 - PCV Grommet- wedge - .71" ID 1.225" OD
http://www.napaonline.com/Catalog/Ca...043_0432519328
CRB 29117 - PCV Grommet- Deep wedge- no measurements
http://www.napaonline.com/Catalog/Ca...117_0198969950
CRB 29118 - PCV Grommet - Deep wedge - no measurements
http://www.napaonline.com/Catalog/Ca...118_0198984921
NOE 6301074 - Breather grommet- .97" ID 1.7" OD
CRB 29106 - Breather grommet - No measurements
http://www.napaonline.com/Catalog/Ca...106_0198965931
NOE 6301052 - Breather grommet - .97" ID 1.7"OD
http://www.napaonline.com/Catalog/Ca...052_0417217912
CRB 29109 - Breather grommet- Round bottom - Wedge shape - No measurements
http://www.napaonline.com/Catalog/Ca...109_0374666655
Old Dec 27, 2013 | 06:48 PM
Octania's Avatar
Rockauto.com
$8.27 the set, delivered to my door
I cannot comment on fit or quality, having not purchased these items as yet.
I do know that GM parts fit right and work right. In GM rocker covers.
~1" hole for filter canister
AIRTEX / WELLS Part # 2P1002 {#22532566, 385204, PCG102}
w/ 1 in. I.D. x 1-1/2 in. O.D.
$2.42
The PCV Receptacle
DORMAN Part # 42314 {#385283} ID: 0.486"; O.D.: 1.071"; Thickness: 1.248"
PCV to Valve Cover
$2.71
Al2011
Aug 2, 2011 05:17 PM
arodenhiser
Wheels and Tires
Mar 28, 2011 03:48 PM
Joeypete
Brakes/Hydraulic Systems
Jan 20, 2010 07:09 AM
jensenracing77
Feb 22, 2009 07:02 PM
J-(Chicago)
May 26, 2008 08:51 PM
