D-shaped PVC & Breather Grommets- ANyone have napa Pn's?
Old December 26th, 2013, 02:26 PM
Ben
RAMBOW's Avatar
I need to pickup a new set of PCV & valve cover breather gaskets for a new set of valve covers- these are the D-shaped stock style. The online catalog for Napa doesn't list them if you search on 1970 or 1966 oldsmobile 442 as your application... but if i remove the vehicle and just search "pcv grommet" i see several that may be close.
Does anyone happen to have NAPA Pn's jotted down for the right ones?
Thanks!
Ben
RAMBOW is offline
Old December 26th, 2013, 02:58 PM
Octania's Avatar
GM 22532566
no luck today at gmpartsdirect.com
Napa 630-1052
63/64" round ID for PCV filter canister 1969+
For pcv vlave I have only
385283
"GROMMET, valve cover, for PCV valve, all Olds V-8
ID 7/16"
HELP! Brand # 42314 might be same
NON-GM WILL NOT WORK RIGHT- rubber too hard!
That last line was my experience, YMMV. No way was the PCV valve going in that HELP brand chinese POS
Octania is offline
Old December 26th, 2013, 03:58 PM
major noob
billmerbach's Avatar
I have one or two laying around no rips or tears
billmerbach is offline
Old December 26th, 2013, 04:42 PM
Fusicks has them.
1969w3155 is offline
Old December 26th, 2013, 10:27 PM
Ben
RAMBOW's Avatar
Thanks guys... I'll do some more looking.
I have a counter guy at my local napa who will likely order in all the possible ones and let me pick out the right ones... I was just hoping not to make him do that.
Fusicks has them.
Fusicks wants $10 each for them plus their usual $25 shipping charge for a couple items that could go in a $5 flat rate padded envelope, so I'm trying to avoid that.
Plus the fusick one I ordered 2 years ago split almost immediately, so hoping to find one made by a different mfg anyway.
RAMBOW is offline
Old December 27th, 2013, 07:01 AM
RandyS's Avatar
The Parts Place has them for $8.00, and their shipping is cheaper than Fusicks. I ordered a couple and they look real good.
RandyS is offline
Old December 27th, 2013, 07:42 AM
MOTORHEAD
11971four4two's Avatar
NOE 6301074 napa part number
http://www.napaonline.com/Catalog/Ca...074_0417240032
11971four4two is online now
Old December 27th, 2013, 08:38 AM
Ben
RAMBOW's Avatar
here is my initial list:
NOE 6301364 - PVC Grommet- Support Wedge- .42" ID 1.71"OD http://www.napaonline.com/Catalog/Ca...364_0417215202
NOE 6301043 - PCV Grommet- wedge - .71" ID 1.225" OD
http://www.napaonline.com/Catalog/Ca...043_0432519328
CRB 29117 - PCV Grommet- Deep wedge- no measurements
http://www.napaonline.com/Catalog/Ca...117_0198969950
CRB 29118 - PCV Grommet - Deep wedge - no measurements
http://www.napaonline.com/Catalog/Ca...118_0198984921
NOE 6301074 - Breather grommet- .97" ID 1.7" OD
CRB 29106 - Breather grommet - No measurements
http://www.napaonline.com/Catalog/Ca...106_0198965931
NOE 6301052 - Breather grommet - .97" ID 1.7"OD
http://www.napaonline.com/Catalog/Ca...052_0417217912
CRB 29109 - Breather grommet- Round bottom - Wedge shape - No measurements
http://www.napaonline.com/Catalog/Ca...109_0374666655
RAMBOW is offline
Old December 27th, 2013, 06:48 PM
Octania's Avatar
Rockauto.com
$8.27 the set, delivered to my door
I cannot comment on fit or quality, having not purchased these items as yet.
I do know that GM parts fit right and work right. In GM rocker covers.
~1" hole for filter canister
AIRTEX / WELLS Part # 2P1002 {#22532566, 385204, PCG102}
w/ 1 in. I.D. x 1-1/2 in. O.D.
$2.42
The PCV Receptacle
DORMAN Part # 42314 {#385283} ID: 0.486"; O.D.: 1.071"; Thickness: 1.248"
PCV to Valve Cover
$2.71
Octania is offline
Al2011
August 2nd, 2011 05:17 PM
arodenhiser
Wheels and Tires
March 28th, 2011 03:48 PM
Joeypete
Brakes/Hydraulic Systems
January 20th, 2010 07:09 AM
jensenracing77
February 22nd, 2009 07:02 PM
J-(Chicago)
May 26th, 2008 08:51 PM
Quick Reply: D-shaped PVC & Breather Grommets- ANyone have napa Pn's?
