Carburetor problems
Old Oct 12, 2021 | 07:57 AM
DVS18th's Avatar
Carburetor problems
i have a 61 Oldsmobile dynamic 88.
Problem is the “flap” on top of the carburetor is fully opening when I turn the ignition on. So the engine won’t turn on. If I hold the flap in the closed position then crank the car it will turn on but then I have to manually hold that “flap” to keep it from fully opening and dying out again. Is there a way I can tighten this “flap” so it gives the right amount of air/ gas mix going into the engine? TIA all.
Old Oct 12, 2021 | 11:43 AM
The "flap" is called the choke plate, and apparently your automatic choke mechanism isn't working properly. A thermostatic coil is supposed to hold the choke plate closed when the engine is cold, and as the engine warms up this thermostatic coil expands and opens the choke plate. The problem could be a bad choke coil or it could be a misadjusted or improperly assembled choke linkage.
Old Oct 12, 2021 | 01:02 PM
OLDSter Ralph's Avatar
Have you pressed the gas pedal to the floor to "set the choke" before starting ?
Old Oct 19, 2021 | 11:50 AM
kencarr442's Avatar
Joe knows his sh*t, he's forgotten more than most of us know about Olds! ;p) Check to see if the choke plate linkage rod is attached to a coiled spring on the intake manifold, sounds like the choke isn't even hooked up.
GOOD LUCK! Post/let us know if this worked, we'll throw more ideas your way if needed.
mudbog42
Apr 28, 2019 10:44 AM
deadeyejedi
Apr 12, 2018 06:20 PM
LJ72Cut
May 24, 2017 09:27 AM
eddieunderground
Jan 22, 2013 04:14 PM
allthumbs
Jan 8, 2007 02:24 PM
