turn signal issue
Old Apr 12, 2018 | 03:45 AM
deadeyejedi's Avatar
turn signal issue
have a question on a newly aquired 1980 olds cutlass .when i step on the break the right turn signal indicator light on the dash comes on.and when i use the turn signal both indicator lights come on but dont blink .just got it so havent had time to delve into it .maybe a short ?
Old Apr 12, 2018 | 05:57 PM
Make sure the **** for the four way flashers is pulled all the way out.
Old Apr 12, 2018 | 06:03 PM
Thanks joe , while going over a few things I did mess with that and things started working .the 4 way switch is very stiff . Would spraying wd40 in there harm or help it to work more freely ?
Old Apr 12, 2018 | 06:18 PM
Likely the grease in there has hardened. I would use a silicone spray instead of WD40. Petroleum-based sprays can eventually damage the plastic.
Old Apr 12, 2018 | 06:20 PM
Ok will do thanks for help .
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
Jolly Green
Apr 17, 2009 10:43 PM
JD72OLDS
Dec 2, 2008 09:41 PM
pinky
Sep 30, 2007 06:30 PM
