Correct voltage regulator number for 72 supreme
Old Apr 11, 2018 | 04:28 PM
Oldssupreme's Avatar
Chris
Hi! I have 3 or 4 original metal voltage regulators in a box with numbers stamped on the sides (I don't have them I front of me but I can look and post when I get home). Anyone know the proper number for a 72 350 with ac? Would the proper one depend on the alternator as well? Thanks!
Old Apr 11, 2018 | 06:54 PM
Yellowstatue's Avatar
1119515 exc rear defog & HD cooling & 3.23 performance axle. 1119519 W/ rear defog. Try that.
Old Apr 12, 2018 | 03:07 AM
Chris
Thank you yellowstatue for your reply! So one of the parts cars I parted had the rear defroster (grid lines) and 63 amp alternator. If I use the voltage regulator from that setup with the standard 55 (?) amp alternator will that have any repercussions? Or do I need to make sure the voltage regulator matches the alternator output?
Thanks!
chris
Old Apr 12, 2018 | 07:10 PM
I would use the 63 amp alt with the 1119519 reg.
Old Apr 12, 2018 | 07:36 PM
Chris
Ok. the 63 amp was from a 34000 mile car, but I'm assuming I should probably have it rebuilt? I haven't installed it as I had the 55 amp alternator rebuilt 20 years ago and running on my car before I started the resto in 2011. Do voltage regulators often go bad? Do they need to be rebuilt if they are original?
Chris
delta_88_germany
Feb 22, 2014 01:48 PM
Pacecar
Mar 16, 2012 01:33 PM
ow30442
Sep 2, 2008 02:51 PM
rocket69
Aug 14, 2008 09:09 AM
and1stp
Sep 17, 2006 07:31 PM
