Battery cable mount location
I have a 1969 Oldsmobile Cutlass with a 455 in it. I would like to know where the stock location of where to mount the negative battery cable to? I cannot seem to find this anywhere.
Check your 1969 Cutlass/4-4-2 assembly manual, manual section 12, page 131. It shows routing with or without A/C. If you don't have an assembly manual for your car, I highly recommend obtaining one. They are easily available through ebay and a wealth of information at your fingertips.
Randy C.
Randy C.
I have the assembly manual on its way. Thanks for the reply. Just to make sure I fully understand, you are referring to using one of the bolts that holds the power steering pump to the engine block?
No, don't use any of the P/S bolt holes or P/S bracket holes.
See the bolt in behind the pump with the silver ground cable end with black negative batt cable going to it.
See photo attached below,
Hope this helps,
Eric
Hope this helps,
Eric
It is a shallow hole too so you will need the correct bolt and star washer to be correct. The black bolts in the Fusick link are what I am referring to. Make sure all your grounds are clean and tight. Factory hardware goes a long way to ensuring factory spec grounds. Clean your positives too at the battery and at the starter. Same for the alternator connections. Clean connections = less resistance = less heat = a happy car.
http://www.fusickautomotiveproducts....?dept=76&val=5
Welcome to CO Jesse,
Don't hesitate to ask any questions here, so many guys here to help. A Chassis Service Manual will certainly come in handy for doing the actual job once your questions have been answered.
Cruzn 66 always has nice manuals for sale here , you could PM him and ask if he has any available when your ready.
I keep my manual on my fender when quick reference while working on most area's of my car.
Cheers
Eric
Cheers
Eric
