Battery cable mount location
Old Jul 16, 2018 | 11:21 AM
jesse.havlik's Avatar
I have a 1969 Oldsmobile Cutlass with a 455 in it. I would like to know where the stock location of where to mount the negative battery cable to? I cannot seem to find this anywhere.
Old Jul 16, 2018 | 12:31 PM
rcorrigan5's Avatar
Randy C.
Check your 1969 Cutlass/4-4-2 assembly manual, manual section 12, page 131. It shows routing with or without A/C. If you don't have an assembly manual for your car, I highly recommend obtaining one. They are easily available through ebay and a wealth of information at your fingertips.
Randy C.
Old Jul 16, 2018 | 12:38 PM
RetroRanger's Avatar
72 Olds CS
to the engine block behind the PS pump.
also ground from the pass side head to the firewall w braid strap
Old Jul 17, 2018 | 06:13 AM
I have the assembly manual on its way. Thanks for the reply. Just to make sure I fully understand, you are referring to using one of the bolts that holds the power steering pump to the engine block?
Old Jul 17, 2018 | 01:20 PM
76olds's Avatar
Hookers under Hood
No, don't use any of the P/S bolt holes or P/S bracket holes.
See the bolt in behind the pump with the silver ground cable end with black negative batt cable going to it.
See photo attached below,
Hope this helps,
Eric
Old Jul 17, 2018 | 02:23 PM
72 Olds CS
i was mistaken looks like its the drivers side head it bolts too....heres another view
Old Jul 17, 2018 | 03:33 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
It is a shallow hole too so you will need the correct bolt and star washer to be correct. The black bolts in the Fusick link are what I am referring to. Make sure all your grounds are clean and tight. Factory hardware goes a long way to ensuring factory spec grounds. Clean your positives too at the battery and at the starter. Same for the alternator connections. Clean connections = less resistance = less heat = a happy car.
http://www.fusickautomotiveproducts....?dept=76&val=5
Old Jul 18, 2018 | 06:41 AM
Thanks for all the great facts here. I'm glad I joined this group. I will need all the help I can get as I have never owned a Oldsmobile before. Thanks again.
Old Jul 18, 2018 | 04:50 PM
76olds's Avatar
Hookers under Hood
Welcome to CO Jesse,
Don't hesitate to ask any questions here, so many guys here to help. A Chassis Service Manual will certainly come in handy for doing the actual job once your questions have been answered.
Cruzn 66 always has nice manuals for sale here , you could PM him and ask if he has any available when your ready.
I keep my manual on my fender when quick reference while working on most area's of my car.
Cheers
Eric
68Tom
Sep 12, 2024 01:57 PM
Richard Miller
Aug 27, 2019 02:31 PM
rothlane'68
Aug 1, 2017 06:17 PM
The Bug Man
Feb 3, 2016 03:00 PM
W31driver
Oct 30, 2012 04:40 PM
