72 cs a frame bushings
Old Aug 26, 2014 | 08:47 AM
72cutlassdog's Avatar
When driving my car I hear a lot of squeaking in the front that drives me crazy. My dad said it's the a frame bushings. what all do I need to replace to solve the problem. Here is a picture of mines.
Old Aug 26, 2014 | 09:31 AM
brown7373's Avatar
Probably need to replace the upper and lower control arm bushings. Your picture is of the 2 upper. There are also 2 lower. You might try shooting a little silicone lubricant in them, but that is at best a temporary fix of the symptom of worn out bushings.
It is a pretty big job. You need to remove the control arms, which entails removing, or at least taking all the load off the spring so you can remove and reinstall the bushings. Many people also take the occasion to replace the ball joints unless they are fine. This is not my car, but I did the same job and also replaced the springs and converted from power drum brakes to power disk brakes since everything is pretty much off the car.
Here is a link that goes through the whole front end rebuild. https://classicoldsmobile.com/forums...tml#post264807
Old Aug 26, 2014 | 09:55 AM
Octania's Avatar
"I hear a lot of squeaking in the front that drives me crazy"
Turn the radio up.
Old Sep 23, 2014 | 08:01 AM
Finally finished my a frame bushings. I changed the upper ball joints too. The previous owner by the looks of it never greased them. Car is quiet like it should be now.
Old Sep 23, 2014 | 08:44 AM
KDV's Avatar
KDV
Glad it went well!
I recently rebuilt my front end with the extensive help of Rob's front end rebuild thread.
The alignment shop even knocked $10 off of my alignment because everything was new and they didn't have to bust any bolts loose.
1978 Oldsmobile Omega
Jul 11, 2014 11:58 AM
rcktdoc
Jul 9, 2014 02:52 PM
62 Cutlass Convert
27
Mar 5, 2014 09:54 AM
DJMatthews
Dec 5, 2006 01:28 PM
