'71 442 Build Sheet
Old June 7th, 2020 | 09:22 AM
Gumby's Avatar
'71 442 Build Sheet
I'm trying to determine which available factory options that are currently on my '71 442 were original to the vehicle. I have the build sheet.
Question: Will ALL options original to car be listed on the build sheet?
Thanks for any help.
Old June 7th, 2020 | 09:25 AM
Gumby's Avatar
The build sheet:
File Type: pdf
Old June 7th, 2020 | 09:56 AM
69HO43's Avatar
Not on that piece. Broadcast sheet or card. Just lists some major options on the car. Body tag number should match the broadcast sheet.
Build sheet has ALL the factory-installed equipment (not dealer installed, however), usually codes, VIN, RPOs, and list of optional equipment included, selling/destination dealer, etc.,
But being a Lansing built car, the broadcast sheet will be as close as you'll probably get. Full build sheets on Lansing cars are like hen's teeth.
Old June 7th, 2020 | 10:11 AM
Rocket Renegade!
That's not a build sheet, it's an IBM trim card, so it will not list everything you're looking for although it does appear to confirm W-30 with air conditioning and stereo tape so you should find that helpful. Real build sheets are rare, and pretty much non-existent on Lansing-built cars.
Old June 7th, 2020 | 10:21 AM
Gumby's Avatar
Thanks for the info. The car is matching numbers engine and tranny with the following additional (factory?) options not listed on trim card:
Power steering
Power brakes
A/T with Hurst dual-gate
rear speakers
8-Track
Tilt
Cruise
Power locks
Power Windows
Super-Lift rear shocks
Any way to tell if these options are original to car?
Old June 7th, 2020 | 10:30 AM
Gumby's Avatar
Power steering
Power brakes
rear speakers
8-Track
Tilt
Cruise
Power locks
Power Windows
….and power driver seat
Old June 7th, 2020 | 11:35 AM
1970cs's Avatar
Lansing built
Not really without an original window sticker and the aforementioned.
Pat
Old June 7th, 2020 | 11:53 AM
anthonyP's Avatar
With all those options surprise no factory air conditioning.
Old June 7th, 2020 | 12:03 PM
Gumby's Avatar
Actually, it's a W-30 with AC. 1 0f 10 convertible W-30s with AC. I didn't list it because the trim card above already lists those.
Old June 7th, 2020 | 12:32 PM
Rocket Renegade!
C-60 on the trim card is A/C.
pcard
October 28th, 2024 10:57 AM
ostricker
April 19th, 2019 11:50 AM
stetzie
January 15th, 2011 10:21 AM
Gearhead442
January 21st, 2010 09:32 AM
MyWildest
February 8th, 2009 05:58 PM
Quick Reply: '71 442 Build Sheet
