'71 442 Build Sheet
Old Jun 7, 2020 | 08:22 AM
Gumby's Avatar
'71 442 Build Sheet
I'm trying to determine which available factory options that are currently on my '71 442 were original to the vehicle. I have the build sheet.
Question: Will ALL options original to car be listed on the build sheet?
Thanks for any help.
Old Jun 7, 2020 | 08:25 AM
Gumby's Avatar
The build sheet:
File Type: pdf
Old Jun 7, 2020 | 08:56 AM
69HO43's Avatar
Not on that piece. Broadcast sheet or card. Just lists some major options on the car. Body tag number should match the broadcast sheet.
Build sheet has ALL the factory-installed equipment (not dealer installed, however), usually codes, VIN, RPOs, and list of optional equipment included, selling/destination dealer, etc.,
But being a Lansing built car, the broadcast sheet will be as close as you'll probably get. Full build sheets on Lansing cars are like hen's teeth.
Old Jun 7, 2020 | 09:11 AM
That's not a build sheet, it's an IBM trim card, so it will not list everything you're looking for although it does appear to confirm W-30 with air conditioning and stereo tape so you should find that helpful. Real build sheets are rare, and pretty much non-existent on Lansing-built cars.
Old Jun 7, 2020 | 09:21 AM
Gumby's Avatar
Thanks for the info. The car is matching numbers engine and tranny with the following additional (factory?) options not listed on trim card:
Power steering
Power brakes
A/T with Hurst dual-gate
rear speakers
8-Track
Tilt
Cruise
Power locks
Power Windows
Super-Lift rear shocks
Any way to tell if these options are original to car?
Old Jun 7, 2020 | 09:30 AM
Gumby's Avatar
Power steering
Power brakes
rear speakers
8-Track
Tilt
Cruise
Power locks
Power Windows
….and power driver seat
Old Jun 7, 2020 | 10:35 AM
1970cs's Avatar
Lansing built
Not really without an original window sticker and the aforementioned.
Pat
Old Jun 7, 2020 | 10:53 AM
anthonyP's Avatar
With all those options surprise no factory air conditioning.
Old Jun 7, 2020 | 11:03 AM
Gumby's Avatar
Actually, it's a W-30 with AC. 1 0f 10 convertible W-30s with AC. I didn't list it because the trim card above already lists those.
Old Jun 7, 2020 | 11:32 AM
C-60 on the trim card is A/C.
pcard
Nov 8, 2024 09:39 AM
ostricker
Apr 19, 2019 10:50 AM
stetzie
Jan 15, 2011 09:21 AM
Gearhead442
Jan 21, 2010 08:32 AM
MyWildest
Feb 8, 2009 04:58 PM
